Husqy GT52XLS Drive Belt issues
   / Husqy GT52XLS Drive Belt issues #1
Richard SC
Husqvarna GT 52XLS
My Husqy GT52XLS throws it's belt every time I disengage the mower. The tensioner is fine and this just started happening after many mowings. Any thoughts?
   / Husqy GT52XLS Drive Belt issues #2
Belt guide not positioned correctly or missing. Or the belt tension arm is lagging causing slack. Other thought is something is not aligned correctly allowing the belt to ride up on a pulley and jump off.
   / Husqy GT52XLS Drive Belt issues #3
Welcome. A good inspection is in order as Randy pointed out. You didn't say how many hours it has. Should also look for broken spindles or one of the blade spindles binding- so see that they turn freely. Tension is adjustable as well on these if I recall.
Thank you both, I will check these things out and update you.
Spring Tooth Plow (A48837)
Spring Tooth Plow...
Bush Hog 306 72in. Commercial Mower Attachment (A49346)
Bush Hog 306 72in...
2022 Club Car...
2016 VOLVO SINGLE SLEEPER ROAD TRACTOR (A50459)
2016 VOLVO SINGLE...
2016 JOHN DEERE 35G EXCAVATOR (A50458)
2016 JOHN DEERE...
UNUSED LANDHONOR SKID STEER ROOT RAKE (A50460)
UNUSED LANDHONOR...
