Husqy GT52XLS Drive Belt issues
   / Husqy GT52XLS Drive Belt issues #1
Richard SC
Husqvarna GT 52XLS
My Husqy GT52XLS throws it's belt every time I disengage the mower. The tensioner is fine and this just started happening after many mowings. Any thoughts?
   / Husqy GT52XLS Drive Belt issues #2
Belt guide not positioned correctly or missing. Or the belt tension arm is lagging causing slack. Other thought is something is not aligned correctly allowing the belt to ride up on a pulley and jump off.
   / Husqy GT52XLS Drive Belt issues #3
Welcome. A good inspection is in order as Randy pointed out. You didn't say how many hours it has. Should also look for broken spindles or one of the blade spindles binding- so see that they turn freely. Tension is adjustable as well on these if I recall.
Thank you both, I will check these things out and update you.
2017 Caterpillar 259D Two Speed Compact Track Loader Skid Steer (A50322)
2017 Caterpillar...
2013 TRAVIS BODY & TRAILER, INC. ALUMINUM BELLY DUMP (A50854)
2013 TRAVIS BODY &...
More info coming soon! (A49346)
More info coming...
1268 (A50490)
1268 (A50490)
2022 New Holland Workmaster 120 MFWD Compact Utility Tractor (A51039)
2022 New Holland...
8 DRILL COLLAR (A50854)
8 DRILL COLLAR...
