Husqvarna YTH24V48 sloppy steering
   / Husqvarna YTH24V48 sloppy steering #1
mikefrommichigan
I own a 4 year old Husqvarna YTH24V48 (Product 960450063).
Like others this tractor's steering is becoming sloppy.
I tightened the steering wheel nut as it was a little loose but this did not fix it.
The parts diagram shows that the bushing part # is 585029802, but when I removed the dash panel to see the old bushing, the bushing was white and plastic and not metal.
The old bushing also did not have 2 bolt holes on it.
I contacted Husqvarna to determine which bushing I should use. They replied that this tractor uses the 585029802 bushing.
Anyone know which bushing I should use?
I do not want to remove the old bushing and have my tractor unusable for too long.
I may end up trying to adapt the metal bushing as member GT48DXLS did in a message dated Feb 15 2021 if I cannot determine which bushing is the correct one, assuming the shaft diameter is the same
Thanks
   / Husqvarna YTH24V48 sloppy steering #2
Thanks
Hey Mike, I have the same tractor as you, a 2014 model with 230hrs. We have had that issue for about 5 yrs, we just deal with it. I totally understand why you want to fix it
I think I saw a you tube video about someone using a brass bushing. Dennis Coffee’s YouTube channel he’s all about that tractor! Good luck 🇺🇦☮️✌🏻
   / Husqvarna YTH24V48 sloppy steering #3
Plastic?! Figures. I posted in a chainsaw thread how hessvarna is really cheaping out on their saws. No clips at all on the fuel lines.
I will not buy another hussyvarna machine.
   / Husqvarna YTH24V48 sloppy steering #4
Yes, the little plastic bushing is replaced with that style.
   / Husqvarna YTH24V48 sloppy steering #5
I have a craftsman which is just a rebadged husky. I replaced the upper plastic bushing with a block that had a bronze bushing in it.
The lower steel bushing got loose so I drilled it out and pressed in a bronze bushing.
My steering shaft is 3/4” so finding bushings is easy.
Thanks for the replies. Been on vacation so couldn't answer sooner. I have decided to wait until fall to deal with it and hope it does not completely give out before then.
   / Husqvarna YTH24V48 sloppy steering #7
Mine has been like that for several years now at the least!
1839 (A51248)
1839 (A51248)
2017 PJ Bumper Pull Equipment Trailer (A53117)
2017 PJ Bumper...
1994 Fiat Allis 65-B Motor Grader (A52384)
1994 Fiat Allis...
1987 LANDALL 48ft Hydraulic Slide Axle T/A Drop Deck Trailer (A51692)
1987 LANDALL 48ft...
1998 C6500 Chevy, 3126 Cat Engine (A52384)
1998 C6500 Chevy...
JOHN DEERE 4066R LOT NUMBER 23 (A53084)
JOHN DEERE 4066R...
