husqvarna oil question
   / husqvarna oil question #1
BlackOps
Platinum Member
northern middle tn
Mahindra Max 25
could not find the right place but figured I'd try here.
I unfortunately have a husqvarna garden tractor - innotek twin 24? horse and the pdf manual says use 30 or 5w -30 oil? all above 32 degrees. no mention of under. the dealer who was a joke said use 10w - 30. so like WTF????? i bought the 30 since that was mentioned but not sure if that will cause harm or if i need to go get 5w - 30 or even the 10w- 30.
comments and help most welcome. contacting husqvarna is a joke too by the way.
   / husqvarna oil question #2
All are really fine for summer operation. 10W30 is typically what is used. SAE 30 offers some extra protection against heat in air cooled engines. If I were using it in winter, I would go with a 5W30 synthetic.
   / husqvarna oil question #3
Think 10w30 is the old plain 30w, just relabeled.
5w30 or even 0w30 would be even better, all year round. I recently found 0w30 M1 ESP at Advance Auto. Ordered some for the 2025R.
ok thanks - i may end up trying to get the 5w-30.but since it gets hot here maybe just use the 30. so much cheaper here too.
   / husqvarna oil question #5
I use Amsoil small engine oil, a tough full synthetic oil, and if you forget to service it on time it is safe for up to 200 hours. Not that I would do that, but nice to know. I will include the link below for you to check it out. See the various grades and decide which is appropriate for your application/weather. Open for example the 10w30 info, then specifications and then data info, and learn alot about oils. The 10w30 has a pour point of -40f and fire point of over 500f! See how many other oils could do that....very few. I get it shipped right to my door, and when there are promotions like free shipping, I get a case of it... Dutchy
hey thanks - will check it out later today when i get back in. stuff to do before storms next 2 days.
   / husqvarna oil question #7
I would put 10w 30 SYNTHETIC in it, I prefer Mobil 1 brand...
That's what I run in all of my air cooled gas engines, and I've never had any kind of oil related failure in even one of them.
SR
UNVERFERTH 330 8 AND 1/2 INCH EXTENSION STUB TUBE WELDMENT FOR FRAME (A53472)
UNVERFERTH 330 8...
New/Unused Quick Attach Auger with Three Bits (A51573)
New/Unused Quick...
New/Unused Gold Mountain Container Shelter 20ft x 40ft (A51573)
New/Unused Gold...
2009 Volvo VHD Tandem Dump Truck, VIN # 4V5KC9EF19N270338 (A51572)
2009 Volvo VHD...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
