jpilk99
- Joined
- Feb 19, 2011
- Messages
- 344
- Location
- Bolton, MA
- Tractor
- 1983 Ford 1700, 4WD, 770 Loader, Woods backhoe, Woods brush hog,etc.
Hi all,
I may be resurrecting's an older post (below) when I had issues with the mower deck belt jumping off. Just like in that post, I think i've checked everything, from drive pulley under the motor, to the deck itself, all spindles are on the same plan, none are bent or lose. As noted in that previous thread, I had installed a 'tensioner pulley Limit Stop' bolt to keep that tension pulley from flapping too lose... But here I am back with brand new belt, everything grease, deck set & adjusted to proper height (with the rear about a 1/2 inch higher than front) and yet I can't figure out why - after only about 100' of mowing over perfectly flat grass, the belt inexplicitly jumps off. Time after time. I will say the machine is about 10-11 years old with almost 500 hours. The mower deck ain't brandy new, but, it doesn't seem that bad. Not sure what Could go bad, bad enough to cause brand new belt to jump for no reason, or at least none that I can see.
www.tractorbynet.com
Jay
Mower deck belt jumping off again
It seems as though it may be aggravated by the fact the deck in lowered. Where did it jump from? Remember as you scratch your head where the belt came off, think of the belt being pushed around the pulley system rather than being drawn around. I remember you saying this previously, great...
Jay
