jpilk99
- Joined
- Feb 19, 2011
- Messages
- 355
- Location
- Bolton, MA
- Tractor
- 1983 Ford 1700, 4WD, 770 Loader, Woods backhoe, Woods brush hog,etc.
Hi all.
I think I left part of my brain somewhere and can't find it. I've repaired 100s of small engine machines over the years, mostly resolving poor running conditions due to bad/dirty carbs. So when my dear Husqy riding lawn mower, with a 24horse twin Kawasaki engine, just up & quit the other day ...at first I thought I was out of gas. Filled her up and it wouldn't stay running. If I pull the choke, it's starts right up - but 3 seconds after turning off choke, it dies. If I quickly pull the choke again, it perks right up. Turn off choke, it dies after 2 or 3 seconds.
So I figured I must've sucked in some piece of crud into the carb. Took carb off, bowl looked pretty darned clean. Unscrewed the ...main jet (in the middle - sorry my terminology is not great) and it was darned clean as well. Ran a carb cleaner brush up through it, hit it with carb cleaner, then canned air to blow it out. Then went into the "tube" that the main jet came out of and shot carb cleaner and poked into it with a thin guage wire. A little more carb cleaner and air; and then put the main jet back in. Un hinged the float, (inspected - no cracks or anything), removed the needle - rubber tip looked good/sharp. Confirmed there wasn't a rubber washer/seat in the ...primary jet and then gave it a few blasts of carb cleaner and air, then poked with wire. Made sure fuel inlet was clean, sprayed a bit more carb cleaner and canned air, then put it back together.
Same issue.
Replaced fuel pump, (which I don't think was the issue - as it starts and runs, on choke - and I disconnected the fuel hose to the carb and cranked engine and gas pumped out). Still same issue. Replaced fuel line between carb and pump, pump and filter and the breaker line to the block.
Still same issue.
With the hood off the engine, I can see - after starting it and turning off choke, that right as it begins to die, the governor is opening the throttle to full open.... then it dies.
What am I missing?
Same issue.
Still same issue.
What am I missing?
