Husqvarna 2448 bogging down
   / Husqvarna 2448 bogging down #1
Kelytee
Pendleton, KY
Husqvarna 2448T
I have a 2005 2448, I put a brand new engine on it last year as the old one wore out. The only "bolt on" alternative was a up grade in HP to a 27 HP. it's been working great until recently it Boggs down win engaging the PTO. the belt isn't completely bad, and the clutch is working, any idea's?
   / Husqvarna 2448 bogging down #2
as was replyed to me on a similar question, someone (i forgot) said the bearing can seize. Can U turn it free and easy??
   / Husqvarna 2448 bogging down #3
If its bogging down check to make sure your fuel is good, make sure the filter isn't clogged. Also make sure the headlight wire isn't melting and shorting on the muffler causing a short. I have the same tractor with a similar issue and it turned out to be the short. It could also be a carb issue-try using a little sea foam in the tank.
It sounds good until you put it under load and then it bogs down. You can also check to make sure the blades aren't seized by releasing the belt lever and making sure they each turn freely.
   / Husqvarna 2448 bogging down #4
I would look to a clogged air filter.
UNUSED Heavy Duty Ratchet Strap Set (A53117)
UNUSED Heavy Duty...
AUCTION STARTS HERE @ 9AM (A51406)
AUCTION STARTS...
CAT CS563 (A47477)
CAT CS563 (A47477)
2018 Chevrolet Silverado 3500HD 4x4 Crew Cab 9FT Flatbed Truck (A51692)
2018 Chevrolet...
2013 TALBERT TRI-AXLE DETACH TRAILER (A53843)
2013 TALBERT...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
