I've had this cutter about 8 years. It has always started easily and run smoothly. Last week it was just fine but yesterday it would not start. I noticed the primer bulb was cracked so I replaced that and the spark plug (since the original plug was still in it). Could not get it to crank. I took the carb apart and clean it even though it looked fine. I pulled the plug and it was saturated with gas. I checked the spark and it appeared weak to me. I replaced it and it cranked momentarily, but it died when I tried to throttle up. I reset the ignition module gap but the spark was still weak. Could it be the ignition module has gone bad?
