Husky 55 Won't Run
   / Husky 55 Won't Run #12
Non serviceable meaning that the screen is not removable from the inside of the one piece muffler that is either crimped together or welded.Similar to a catalytic converter.
This screen is held on by a screw outside the muffler on these. They are "serviceable". I initially thought you meant "non serviceable" because they were no longer available or something because the screen on these are so accessible.
   / Husky 55 Won't Run #13
   / Husky 55 Won't Run #14
With working on so many models between the husky line and the poulan line it is hard to remember what muffler type is used on what model.
   / Husky 55 Won't Run #15
Thanks all responders!
Muffler screen is OK, I can see right through it. But I will look into the fuel line. Maybe plug the end, blow in, and see if it holds air.
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
SDLanch SDLD25 Rubber Track Dumper (A57149)
SDLanch SDLD25...
2021 Kubota SVL75-2 (A57148)
2021 Kubota...
7ft Workbench (A57454)
Liebherr PR736 LGP Crawler Dozer, S/N & PIN# 1155-17697, ID# 93501138, Turbo Diesel Engine, 13' (A59076)
Liebherr PR736 LGP...
(2) 235/65R17 TIRES (A58374)
(2) 235/65R17...
