husky 455 rancher chain oil problem
   / husky 455 rancher chain oil problem #1
klindstadt
I have a husky 455 rancher and the chain oil is not putting out enough oil, have a 20 bar and have set the adjustment to the highest output but still not enough oil I have the build up on the chain, cleaned the oil out put space behind the bar and the bar it self but still not enough ???? Use it to cut about 5 to 7 cord of wood a year great saw
Thanks
   / husky 455 rancher chain oil problem #2
Hmmm. I have the 450 and this is what I would do:
Make sure that the rubber seal on the side of the saw that moves oil to the bar isn't torn or clogged.
Empty the oil tank and see if sawdust or dirt has gotten in there and clogged up the pump intake.
Good luck!
   / husky 455 rancher chain oil problem #3
There is a strainer on the oil tank's pickup rubber tube-same as in the fuel tank. I found a nice sized crack in the rubber fuel tube at the strainer's neck. Pull it out intact with a pair of long needle nosed pliers and have a look.
   / husky 455 rancher chain oil problem #4
If it's a new saw ,or bar , look at the oil hole in the bar as well as looking at what the others have said . Had a 372 that came with the hole plugged .
CUSHMAN HAULER 1200 GAS GOLF CART (A51406)
CUSHMAN HAULER...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
2008 CATERPILLAR M322D MOBILE EXCAVATOR (A51406)
2008 CATERPILLAR...
2018 PINSA 130BBL VACUUM TRAILER (A53843)
2018 PINSA 130BBL...
2017 CATERPILLAR D11T DOZER (A52705)
2017 CATERPILLAR...
