husky 455 rancher chain oil problem
   / husky 455 rancher chain oil problem #1
klindstadt
I have a husky 455 rancher and the chain oil is not putting out enough oil, have a 20 bar and have set the adjustment to the highest output but still not enough oil I have the build up on the chain, cleaned the oil out put space behind the bar and the bar it self but still not enough ???? Use it to cut about 5 to 7 cord of wood a year great saw
   / husky 455 rancher chain oil problem #2
Hmmm. I have the 450 and this is what I would do:
Make sure that the rubber seal on the side of the saw that moves oil to the bar isn't torn or clogged.
Empty the oil tank and see if sawdust or dirt has gotten in there and clogged up the pump intake.
Good luck!
   / husky 455 rancher chain oil problem #3
There is a strainer on the oil tank's pickup rubber tube-same as in the fuel tank. I found a nice sized crack in the rubber fuel tube at the strainer's neck. Pull it out intact with a pair of long needle nosed pliers and have a look.
   / husky 455 rancher chain oil problem #4
If it's a new saw ,or bar , look at the oil hole in the bar as well as looking at what the others have said . Had a 372 that came with the hole plugged .
1996 Timpte 46ft Hopper (A55301)
1996 Timpte 46ft...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A54814)
2015 Peterbilt 320...
40ft Shipping Container (A52377)
40ft Shipping...
KODIAK 10' HD ROTARY MOWER (A51406)
KODIAK 10' HD...
2005 GMC C8500 CHASSIS TRUCK (A54756)
2005 GMC C8500...
2021 Freightliner Cascadia 116 T/A Day Cab Truck Tractor (A52377)
2021 Freightliner...
