Husky 359 bogging
/ Husky 359 bogging #1
trado
Got a 359 saw that has developed an issue. It will saw like a champ and then big down then run like a champ. Sometimes it will bog down to where it will shutoff and when you start it right back up it saws like a champ again. Sometimes though it will not start till it cools down 10 minutes. Any ideas. I changed the plug, air filter and fuel filter
/ Husky 359 bogging #2
The next thing I would do is check the fuel line for cracks or pinholes, after that I'd put a rebuild kit in the carburetor. Renewing the diaphragm and fuel pump gaskets will fix 90% problems I see with chainsaws.
/ Husky 359 bogging #3
Like said, fuel line first. I'd just replace it if it's more than a couple years old.
If that doesn't do it, it's likely a bad carb. Some of these saws have a carb problem and need not just a rebuild kit, but the 'right' rebuild kit. Been discussed to death on the big chainsaw forum.
2004 GMC Sierra Pickup Truck, VIN # 1GTHK23U24F110736 (A65563)
2004 GMC Sierra...
New/Unused Mini Quick Attach Auger with Bit (A65583)
New/Unused Mini...
2016 Freightliner 108SD Truck (A64194)
2016 Freightliner...
(4) Tires and Rims (A65640)
(4) Tires and Rims...
International 130 Manure Spreader (A66408)
International 130...
2020 INTERNATIONAL LT625 48" SLEEPER (A62613)
2020 INTERNATIONAL...
