Huski 450 problems
   / Huski 450 problems #11
The oil hole may be only partially blocked. Oil will spray between cuts but due to the reduced flow, not enough oil overall. Same situation that I had on the new Dolmar. Would oil between cuts but chain would sieze to bar and would get hot enough to remove the bar paint on large cuts and oil hole would plug up from the fine pieces of sawdust.
The oil holes that I have found were off between .070-.140 inch too high, blocking the top half of the oil hole.
Atlas Copco XAS90JD Portable Air Compressor (A57453)
Atlas Copco...
2019 CATERPILLAR  XQ60 GENERATOR (A58216)
2019 CATERPILLAR...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Honda Pioneer SXS700 4X4 Utility Cart (A55758)
Honda Pioneer...
2007 FORD F-550 XL SUPER DUTY CHASSIS TRUCK (A58375)
2007 FORD F-550 XL...
Giyi Mini 40" Land Leveler (A57149)
Giyi Mini 40" Land...
