Husco Valve port type question
   / Husco Valve port type question #1
/pine
Super Star Member
I have a mid '90's HUSCO FEL valve...can anyone offer an educated/experienced guess at what thread type the inlet/outlet and PB ports are? ORB, NTP?
   / Husco Valve port type question #2
No clue. Can you at least post some pictures?
Sorry, I thought maybe all HUSCO valves were the same...
I won't be in GA (where tractor is) for another month or so but I do have some pics...
I am trying to accumulate as many of the fittings/adapters that I will need while I'm waiting on Spring and while I'm close to several hydraulic shops including a Goodyear hose and hydraulic shop.
   / Husco Valve port type question #4
Pics are worth a thousand words:thumbsup:
They look like ORB's because of the locknut at the base of the fitting, NPT's would just have threads there. Probably -6 (3/8") sized, but you will need to measure them to be sure.
OK that's great to ID them as ORB...thanks...
anyone care to guess at the size ? #8 maybe?
thanks
Sorry I did read it ...my mind must have just quit registering what I was reading...
thanks...
   / Husco Valve port type question #9
The Husco valve on my Kubota B2400 with a L351 loader has -6 ORB ports.
Another question about re-plumbing the above valve...
I will be adding a single spool valve with PB coming off the PB on the above mentioned valve...
Can I attach a 'T' where the (current) return line connects to the valve...then connect the existing return as well as the one from the new valve?
Thanks for the confirmation...that information along with Kenny and JJ's observations it could save me a heck of a lot of time plus a lot of miles tracking them (ORB fittings) once I'm in the hills...
There is a brand new TSC store about 30 miles away but having a few #6 ORB connectors with me will be a big advantage...
Normally I would ask if all the ports are the same size...as some valves have larger inlet/outlet ports than the working ports by one size...but since I already have a stock of #8 ORB fittings I should be OK if that is the case with my valve...
Thanks for the reply
2020 Exiss Escape 7306 LQ T/A Gooseneck Horse Trailer (A50322)
2020 Exiss Escape...
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A53117)
2025 K0720 UNUSED...
Quick Hitch Skid Steer Attachment (A51691)
Quick Hitch Skid...
2020 Massey Ferguson 1840 Small Square Baler - High-Performance Hay Baler (A53473)
2020 Massey...
20 ft. Shipping Container (A53117)
20 ft. Shipping...
Engel 20' Boat (A50121)
Engel 20' Boat...
