Husco Loader Valve Part Number
/ Husco Loader Valve Part Number #1
Jim1764
Webster, MA USA
1999 Kubota L3710 GST
Hello, I'm looking to upgrade my loader valve on my LA681 loader from the "Dash" mounted stick type control to a "Fender" mounted joy stick type control. Does anyone know if the Husco valve is the same on these two types of controls? What is the Husco / Kubota part number for this Joy stick type control? My LA681 is mounted on a L3710 tractor.
Thanks,
Jim
/ Husco Loader Valve Part Number #3
The only place you will be able to get parts or a replacement for the valve is from Kubota. Husco will not discuss anything about the proprietary valves they make for Kubota. Been there, done that.
If I am not mistaken, the fender mounted joystick is connected to the loader valve by a set of cables. This is a similar setup to what you can buy for the Prince SV valves but it probably won't work on the Kubota valve.
/ Husco Loader Valve Part Number #4
Mad,
The tangs on the ends of the spools are the same on the K/H valve as they are on the standard Husco valves aren't they? If they are he would be able to use a stand controler from Husco. Have you noticed if they are the same?
/ Husco Loader Valve Part Number #5
</font><font color="blue" class="small">( The tangs on the ends of the spools are the same on the K/H valve as they are on the standard Husco valves aren't they? If they are he would be able to use a stand controler from Husco. Have you noticed if they are the same?)</font>
Ah, good guestion. I have only looked at one Kubota setup and I did not pay much attention to the connections. However, I think that the actual valve used in the fender mount cable setup is diferent than the one used for the normal mount. I don't have a parts book to check on it.
</font><font color="blue" class="small">( Mad,
The tangs on the ends of the spools are the same on the K/H valve as they are on the standard Husco valves aren't they? If they are he would be able to use a stand controler from Husco. Have you noticed if they are the same? )</font>
Jerry, Mad, this is what I'm thinking. Looking at the Kubota LA681 parts manual and Husco data sheets I think they are the same valve just configured different. Every now and again I see some of these joy stick/ cable setups for Kubota loaders on ebay. I'm just trying to make sure when I buy one I'm buying the right Husco valve.
Jim
/ Husco Loader Valve Part Number #7
The control valves look similar but are different… all the internal parts for the standard valve, (L2075) have a part number ending in 61xxx, and the remote valve (L2076) part numbers end in71xxx. It looks like the valve bodies are common for both.
Are you planning to remove the valve from the loader and mount it with the tractor? KennyV.
</font><font color="blue" class="small">( Are you planning to remove the valve from the loader and mount it with the tractor? KennyV.
)</font>
Kenny, yes that is part of the reason. I have a Curtis hard cab on the tractor and can not remove the loader because of the current valve/control setup comming thru the cab.
Kenny, are those Kubota or Husco part numbers?
Jim
/ Husco Loader Valve Part Number #10
Hello Jim, I am also trying to convert my L4310 loader mount to a fender mounted joystick control . Did you ever find if a cable set up would work on the Husco valve ? I know this is a old thread but hope you want mind filling me in on how things worked out for you . Ihave 682 loader on my machine which stays with machine when loader is remove . Thanks for any help Tony In Franklin MA
/ Husco Loader Valve Part Number #11
I'm not famaliar with the tractor models you're referring to but JD utilizes the same valve just adds the joystick handle and cables. I see no reason this can't be done with a Husco valve on a Kubota. All one needs is a bracket to hold cables securely at the valve location. JD even utilizes some Husco hyd valves.
/ Husco Loader Valve Part Number #12
Try teleflex and see if they have anything, Look for 1/4' cable.
/ Husco Loader Valve Part Number #13
Thanks for your help I will look into obtaining bracket and cables and a joystick . I am also wondering if i will have to turn the loader valve for cables to work? If so may not be worth the effort and cost . Thanks all
2005 Dodge Ram Crew Cab Pickup Truck (A64556)
2005 Dodge Ram...
2012 FREIGHTLINER M2 6X4 T/A GARBAGE TRUCK (A66091)
2012 FREIGHTLINER...
2021 Redirective Crash Cushion Guardrail (A64556)
2021 Redirective...
2017 Ford F-250 4x4 Crew Cab Pickup Truck (A64556)
2017 Ford F-250...
2018 KENWORTH T680 6X4 T/A SLEEPER TRUCK TRACTOR (A67147)
2018 KENWORTH T680...
2026 DEVELON DX27Z-7 EXCAVATOR (A65053)
2026 DEVELON...
