Huge oak fell!
/ Huge oak fell! #41
Larry, do you think that is from the bark? I'm asking because of a recent visit from a vendor who installed an upgraded wood stove insert in my fireplace.
I told him we only burn oak and madrone; he said it was OK to burn pine just don't burn the pine bark. He said "all" the pitch in pine is in the bark, so if you don't burn the bark you don't have the creosote problem in the flue. Never heard of that before.
We talked about madrone having virtually no ash or residue. He said it is because it has almost no bark.
No, I am burning oak that was down 2 years before I cut it up. All the bark fell off, but I still have to shovel out the stove every couple days. I should have cut more madrone, but the oak was laying on the ground...
Madrone (arbutus menziasii) is the premium firewood. Lights easy, burns hot, leaves a good coal with little ash, and is clean to handle with no moss, bugs, or bark. It also grows like a freaking weed, so there is no shortage. I have reformed my ways and am cutting madrone this winter.
/ Huge oak fell! #42
I'm surprised that Cottonwood lasted as long as it did. It was a clump of small trees growing together.
/ Huge oak fell! #43
Never heard a sound when it fell, weird because about 400 ft downhill from house.
Made really big holes in ground.
You may have just answered that age old question about a tree falling in the forest with nobody around to hear it... :D
/ Huge oak fell! #44
And its corollary, "If you make a decision and your wife is not there, are you still wrong?"
/ Huge oak fell!
I'm all tuckered out!
Dad & I used to cut & split lots of wood for his Fisher momma bear stove. It sits out in their dining room, through a steel plate (about 4ft square) covering fireplace. Years ago I put a vent above stove with a 5" quiet "Boxer" fan in 6" flue pipe that goes through a utility room (we insulated pipe) to another vent in wall opposite stairwell. That works great blowing warm air to upstairs bedrooms.
Dad had the chimney lined years ago and of course his favorite was hardwood but he said if it burns I'll burn it.
A chimney sweep cleaned chimney every year $65, he'd remove that steel plate bolts and vacuum it out after brushing chimney.
Lots of times visiting them I'd fall asleep by the stove.
/ Huge oak fell! #46
Here's a pix of a void in a large madrone on my property. Last winter part of it split away-- revealing the void in the center. I got about 2 1/2 cords of firewood from the part that split off.
The measuring tape is locked at 30". Would probably be out to about 48" if the tree was still intact.
/ Huge oak fell!
Never heard of madrone, probably because I'm on East coast, nice learning new things.
It's a pretty tree.
/ Huge oak fell! #49
It's a pretty tree.
Coppices like a bandit too. Whack it to the ground, wait 5 years, and you will have a madrone thicket. They are almost impossible to kill. Hack and squirt is the only way to get rid of them, or dumping gallons of herbicide from a helicopter. It's a broadleaf evergreen with deciduous bark.
/ Huge oak fell! #50
Sounds like Honey Locust here in Missouri. I cleared a short fence line of old Honey Locust trees 10 years ago. Every Spring new shoots come up from the root system of those removed stumps. I can show you the size of the root system by where the shoots pop up. I fight Honey Locust all the time.
/ Huge oak fell!
Only invasive thing we have here is privet, poison ivy, poison sumac, poison oak, wild grape, honeysuckle, poke berry, thistle, chickweed, periwinkle, johnson grass, assorted ivys, knotweed, bamboo, crabgrass, locust, paradise, and about 100 other things.
/ Huge oak fell! #52
Sounds like a nature preserve.
/ Huge oak fell! #53
Not sure if you do this or not.
I save all the oak bark when I split wood. Then use it in my BBQ for meat-- gives a great smoky flavor to whatever you cook ...
/ Huge oak fell! #54
You forgot to mention Bradford pears and their off-shoots. LOL.
/ Huge oak fell! #55
Never used oak....and most the other "smoking" woods....bark isnt really desirable.
Having burned alot of oak....it doesnt seem too aromatic for me to want to try and smoke meat with. My go-to's are apple and cherry.
/ Huge oak fell! #56
I have some mature/downed apple trees I am cleaning up right now. So I will give that a try.
But if you feel like it, give 100% oak bark a try in place of bbq briquets. I think you will like it. :D
/ Huge oak fell! #58
Might have to try that but the majority of oak around here that I have access to is either red oak or pin oak. Both have a very thin bark
/ Huge oak fell! #59
Or pear. LOL. (see earlier reply)...
Great for pork.
/ Huge oak fell! #60
Well, at least I got your original joke.
Is it something that's very regional to your area? Never heard of it before, never even seen it on any those lists that rank firewood (of which usually 2/3 is stuff that doesn't grow around here).
HYDRO TEK PRESSURE WASHER (A63569)
HYDRO TEK PRESSURE...
LMC Nitrogen Applicator (A62177)
LMC Nitrogen...
2007 FREIGHTLINER COLUMBIA 120 DAYCAB (A63569)
2007 FREIGHTLINER...
Hobart Champion 16 AC/DC Engine-driven Welder and generator (A63689)
Hobart Champion 16...
2016 FREIGHTLINER CASCADIA (A63569)
2016 FREIGHTLINER...
45� Pallet Fork Plate Attachment (A64047)
45� Pallet Fork...
