Huge hydraulic leak!!!
   / Huge hydraulic leak!!! #21
Re: She\'s up and running
John, there's two reliefs in the system. From the charge pump oil flows to the filter. Prior to the filter there is a "filter protective relief valve" mainly for cold oil start ups. Oil then flows through the filter then on to the HST systems, the charge relief is just after the filter. If you look under your tractor on the left side just inboard of the HST filter you will see two allen head plugs right next to each other. The inboard plug is the filter relief and the outboard plug is the charge relief. They are the same exact valves. Charge relief is set at 342-370 PSI and filter relief should be set at 43 PSI higher than charge relief. They are shim adjustable. Therefore filter relief should have more shims.
2013 Ford E-250 Cargo Van (A56858)
2013 Ford E-250...
2018 Komatsu D155AX-8 Crawler Dozer, S/N 100205, PIN# KMT0D126PJC100205, Turbo Diesel Engine, 13' (A59076)
2018 Komatsu...
2011 Ford F-550 ETI ETCMH37IH 37ft. Insulated Material Handling Bucket Truck (A55973)
2011 Ford F-550...
Diamond C Trailers 26ft T/A Flatbed Tilt Trailer (A55787)
Diamond C Trailers...
2017 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A55973)
2017 Chevrolet...
2000 TRAVIS BODY & TRAILER, INC. 39 END DUMP TRAILER (A58214)
2000 TRAVIS BODY &...
