HUGE GT 275 issues...
/ HUGE GT 275 issues... #1
justicedealt
Ok, let me preface this by saying that the engine is free, and IT WILL START!
I went to mow today, and noticed that there was quite a bit of oil leakage. There were 5 spots about the size of a 50 cent piece in a circle that is about the same size as the shaft cutout in the frame/body of the mower. I ASSUMED it was an issue where it was leaking from the drain plug/tube from the block, as I have had it come loose before. I sured it up, checked the oil, and added it appropriately.
While mowing, the engine lost power for a split second then a very large amount of smoke came out of the muffler. I immediately disengaged the PTO for the blades, when the smoke stopped. Still idled well, and was making no noises internally. As I was halfway done, I decided to ride on thinking that I may have put too much oil in it. Well, the second time this happened there was more smoke, and it popped through the exhaust when I cut it off, and I did it immediately... Seal maybe? Ring? Cracked case? It is still not making any noises that I would call unusual from what it normally sounded like. The engine turns freely, and honest to god it will fire up right now if I hit the ignition.
Oh, this is the Kawasaki 17 HP SC, gas, air cooled, hydro static... Thanks...
/ HUGE GT 275 issues... #3
My 275 exhibited everything you said except that it would not restart. It would backfire HUGE. If it backfires and pops, chances are you have a valve issue (that's what mine was). The valve kit was $70 at the JD Dealer.
Massey Ferguson 383 Tractor (A64047)
Massey Ferguson...
Kubota L175 Tractor (A62613)
Kubota L175...
Landhonor Skid Steer Bale Spear, Dual Spear  (A62679)
Landhonor Skid...
1986 Eager Beaver B9D0W 20ft. 11 Ton Tri Axle Dovetail Tag A Long Tailer (A61568)
1986 Eager Beaver...
HARGEE 18' BOGGIE AXLE METAL TRAILER (A63291)
HARGEE 18' BOGGIE...
2018 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A59905)
2018 INTERNATIONAL...
