HUGE GT 275 issues...
   / HUGE GT 275 issues... #1
justicedealt
Ok, let me preface this by saying that the engine is free, and IT WILL START!
I went to mow today, and noticed that there was quite a bit of oil leakage. There were 5 spots about the size of a 50 cent piece in a circle that is about the same size as the shaft cutout in the frame/body of the mower. I ASSUMED it was an issue where it was leaking from the drain plug/tube from the block, as I have had it come loose before. I sured it up, checked the oil, and added it appropriately.
While mowing, the engine lost power for a split second then a very large amount of smoke came out of the muffler. I immediately disengaged the PTO for the blades, when the smoke stopped. Still idled well, and was making no noises internally. As I was halfway done, I decided to ride on thinking that I may have put too much oil in it. Well, the second time this happened there was more smoke, and it popped through the exhaust when I cut it off, and I did it immediately... Seal maybe? Ring? Cracked case? It is still not making any noises that I would call unusual from what it normally sounded like. The engine turns freely, and honest to god it will fire up right now if I hit the ignition.
Oh, this is the Kawasaki 17 HP SC, gas, air cooled, hydro static... Thanks...
   / HUGE GT 275 issues... #3
My 275 exhibited everything you said except that it would not restart. It would backfire HUGE. If it backfires and pops, chances are you have a valve issue (that's what mine was). The valve kit was $70 at the JD Dealer.
2007 Ford Ranger Pickup Truck (A50323)
2007 Ford Ranger...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
UNUSED FUTURE STB47 TELESCOPIC BOOM (A51248)
UNUSED FUTURE...
UNUSED CFG NT18K EXCAVATOR (A51247)
UNUSED CFG NT18K...
49" X 74" EXPANDED METAL RAMP GATE (A51247)
49" X 74" EXPANDED...
2007 CATERPILLAR D5GXL CRAWLER DOZER (A51406)
2007 CATERPILLAR...
