Huber M 500 Maintainer Oil question
   / Huber M 500 Maintainer Oil question #1
cyclemike
Renton, WA
Huber M500
I have an Huber M500 Maintainer I think the year is about 1950. There is a unit between the engine (Continental 4 cyl) and the transmission. It contains the governor and what I believe is the hydraulic pump, at any rate there is a dip stick that says use Type A Fluid. What the heck is the unit and what fluid should I put in it.
   / Huber M 500 Maintainer Oil question #2
The unit is a torque converter and you should add Type A automatic transmission fluid... but you really can't get that easily anymore so just use a Dextron ATF, any version II, III, VI should do.
2011 GMC Acadia SLE SUV (A53424)
2011 GMC Acadia...
UNUSED LANDHONOR HPF-11-3000G HYD PALLET FORKS (A54757)
UNUSED LANDHONOR...
New JMR Mini Skidloader 40" Grapple (A50775)
New JMR Mini...
UNUSED LANDHONOR LHR-EPC40 PLASMA CUTTER (A54757)
UNUSED LANDHONOR...
2017 CATERPILLAR 249D SKID STEER (A52705)
2017 CATERPILLAR...
UNUSED LANDHONOR UNIVERSAL ADAPTER PLATES (A54757)
UNUSED LANDHONOR...
