Hub to axle seal job complete on a 1533, Photos
   / Hub to axle seal job complete on a 1533, Photos #31
Can't locate my owner's manual at the moment, but I think the front axle capacity for fluid is 1.75 gallons. Can anyone confirm or deny this?
   / Hub to axle seal job complete on a 1533, Photos #32
Found it
7.5 liters or 7.9 quarts
   / Hub to axle seal job complete on a 1533, Photos #33
Got the seal replaced.
Forgot tires are loaded....that tiny little front wheel weighs a good bit so putting it back on caused a bit of a headache (out at the farm with minimal tools), but the biggest headache came when trying to pop the snap ring off that apparently holds the hub on. Got it undone and with it, came the hub. Luckily, buddy's head was pretty much out of the way when it fell...knicked him right above the eye, though, so he has a nice bump on it today. He said it didn't think that was all that was holding it on, but in retrospect, most of the pressure/weight goes the other way on the hub.
Lessons learned!
Thanks for all the help, too.
   / Hub to axle seal job complete on a 1533, Photos #34
New member (rarkward). MF 1010 Transmission problem (Hydro). While mowing last year, tractor stopped pulling. Had to toy with foot petel just to get tractor back to shed. Changed all three hyd filters and found low pressure filter insert broken (inside). No debris/fines in oil during trans drainage. Had tractor in shop and repairman could not find a problem as tractor ran fine while there. Ran fine all summer but failed to perform during cold winter months. During past winter, it moved approx. 20 feet, then failed to respond (in either low or high range). Have not had chance to check it out this spring/summer. Wondering if filters and/or type oil has anything to do with problem, or, has something gone bad in trans? Used universal transmission oil during oil change. Would like to tear down and repair myself providing parts are still available and there are some schematics available for the repairs. Note: Read some of your blogs regarding front wheel hub problems with your particular models. Had a similar problem with hub on my 1010. While moving about, hub broke and seperated from mount. Made repairs and used 90 weight gear oil instead. Appears to be working fine and still lubricated during occasional checks, however, I do voluntarily add new 90 wgt lube to maintain fill. Appears, when using recommended oil, seals break allowing oil to escape, thus, rusting internal parts. Thanks for any help received.
   / Hub to axle seal job complete on a 1533, Photos #35
MrSteve, thank you very much for taking the time to take all of the pictures, anotate them, and share this procedure with others. VERY thoughtful of you! I purchaced the parts to fix my 1540. For some reason, a few of your pictures are not working. Can you fix that? I want to make sure i get all of your shots.
Thanks again!
Harry
Thanks again!
Harry
No problem, happy to help... I'm returning a PM to you about the pics, I see them all, I think.
   / Hub to axle seal job complete on a 1533, Photos #37
Could you please pm me the missing pics also. Having same problem with my 1533 but i made it to 1300 hrs. thank you
Harry never replied to my PM, so I am not sure if he seen the pics or not... Not knowing what ones are missing (if someone could tell me I will try to post them again), I sent him the link to my album, Here http://www.tractorbynet.com/photos/showgallery.php/ppuser/21835/cat/500
I will also send you a PM Darry (I will forward the one I sent to Harry).
Thanks Darryl for your help on letting me know what pics were missing...
Something is going on with the gallery on this web site, so I posted the photos on another site and link them here...
Missing, #2
Missing, #9
#2 was just showing the tractor on jack stands.
#9 I believe I was just pointing out to make sure the old seal (inner part of that seal, if you look real close you can see the old inner part of the seal is still there, that rust is the old seal liner and not the spindle) was removed from the top of the drop spindle and to make sure to clean and lube with a bit of axle lube/oil on the new seal before putting everything back together.
Sorry for the pics not showing in my 1st post, not sure what is going on with the gallery on this web site.
   / Hub to axle seal job complete on a 1533, Photos #40
You have been a huge help. Thanks again
2007 Chevrolet Silverado 1500 Pickup Truck (A56858)
2007 Chevrolet...
2013 John Deere 245G LC (A55272)
2013 John Deere...
2007 NEW HOLLAND B95 BACKHOE (A52709)
2007 NEW HOLLAND...
2005 John Deere 200C LC (A55272)
2005 John Deere...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Metal Box with 32 Ratchet Straps (A57454)
Metal Box with 32...
