Jabonee
Platinum Member
If memory serves me I believe there is a tiny little orifice in that HST servo valve. It may be getting plugged with dirt floating back and forth. That would explain the intermittent issue. :confused3:
Uhg. I'm reviving this post since it just happened to my "new to me" 2015 Mahindra 2555. Same exact issues. Tractor has been great for the almost 2 years I've had it. Worked fine all day. Powerwashed and parked it. Next morning the issues started. I thought I had gotten water in something but 3 days later and oil and filter changes, still the same. Works for a few hours then stops. If I hold down either pedal for a while, it will try and creep but struggles. FEL and rear lift work fine.
All the posts I've read just end with no resolution. I know it's 4 years later but did anyone resolve this?
Haven't called the dealer since his response will be to bring it in and I won't see my tractor for 4-6 months.
Have you checked the HST linkage for being loose like missing bolt from the trunnion arm or not tight. How many hours does the tractor have? Also the steering doesn't jerk when turned left or right?Thanks for response Sergei. Sorry, responding so late. Yes hst and yes steering works. Ruled out all the simple things like rim rotation, remote lever in open position, clogged filters, bad oil, etc.
I unplugged and cleaned the pedal switches under the floorboard too. I was really hoping it was the power washing that caused the problem but it's been days now. Called two dealers and both of course said never experienced the problem and to bring it in. Just wanted to try everything I can before shelling out dough needlessly.
