HST vs shuttle
/ HST vs shuttle #81
Just remember this. The only real place gear/ shuttle wins out is if the ground engagement you are doing is right at the maximum the tractor can perform. If it's a task that the tractor can easily do, like grading a driveway then the HST will actually be easier because you can change speeds and direction easier. If it's a task that can be done at a slower speed or if traction is going to be the biggest issue then HST isn't going to be an issue.
Good point. I have driven gear tractors, we have a couple of HST tractors and a GST (power shift) tractor.
I wish the GST tractor was a hydrostatic, it would make snow blowing, mowing and baling easier if I could use an "in between" gear.
Aaron Z
/ HST vs shuttle #82
Glad I read all 9 pages in an attempt to educate myself. Now I am more confused than ever, lol
/ HST vs shuttle #83
There's a lot of opinions. I'ts your needs that matter. Best thing is to think through all the stuff you want to do with a tractor and then test drive lots of tractors while trying to simulate those activities as best you can.
/ HST vs shuttle #84
Once upon a time a long time ago I said my HST (Kubota Grand L 4610 HSTC) outperformed gear shift tractors and failed to notice a challenge to define out perform.
Is it better late than never or better never than late?
Out perform, as in anything you can do with a gear tractor I can do easier or faster with HST with the exception being getting the greatest possible energy turning the wheels. HST uses up just a tiny percentage more of the engines capacity to supply the energy to perform the "magic" of HST. Gear shift tractors are just a tad more efficient in power transfer.
If your tractor was marginal in the HP department for pulling a plow or whatever A N D you did it a lot then there is a chance you would be better served by a gear shifting arrangement Many of us aren't into row cropping or other heavy continuous load type jobs. Many of us want ease of matching job to gear ratio and or want easy and quick direction reversal.
Take for example using a FEL to take buckets of dirt from the ground and load them into a dump trailer. Lots of changes from forward to reverse. With HST you achieve direction change from forward to reverse and reverse to forward with a small motion of your foot leaving both hands for other important jobs: 1. one hand to steer, 2. one hand A L W A Y S on the joy stick when bucket is loaded and you are traveling with it more than a few inches above ground.
I have been there and done that at a gravel pile or filling a trailer with dirt. I can move more material faster with less hassle and fatigue than a somewhat larger more powerful tractor without HST. HST isn't free. It costs more to buy but is more than worth it in most circumstances. My tractor is getting up there in age but has never had a problem with the HST.
Patrick
/ HST vs shuttle #85
Patrick,
Disagree. HST sacrifices more than a tiny bit of HP. In small tractors 5 hp is significant. You would NOT be faster at a repetitive function than me, W/ the newer hydraulic shuttles. The 5125r I use has F-R buttons on the loader joystick. The power reverser lever isn't even necessary, but is available. I can push a button, already under my hand, faster than you can shuffle your feet on floor pedals. Also, HST generates significant heat under load, efficiency loss, and friction wear!.
HST is Old School,, time to catch up.
/ HST vs shuttle #86
Patrick,
I'll agree with that HST may be handy for some people and they may have their place but I much prefer the power shuttles and after a few thousand hours of use the power shuttle will have a much better chance of survival and less expensive maintenance. When your HST's start showing 5000 hours plus and are still working good and are not whining enough to be irritating I may start to change my mind. We load thousands of tons of silage yearly with shuttle tractor loaders I do not believe any of the hydro would do it for the same cost of maintenance and ownership.
/ HST vs shuttle #87
Additionally, unless you can run your brakes with one foot and HST with other, Shuttles are much more precise.
/ HST vs shuttle #88
Why can't you use your right foot to operate the HST and left for the brakes?
/ HST vs shuttle #89
Love my HST.
/ HST vs shuttle #91
My late 70's IH2500b had the directional pedals on the left foot and the brakes on the right foot. Worked great!
My Power Trac has a treadle, with the right foot forward and left foot reverse. No brakes. None. No need. ;)
/ HST vs shuttle #92
Patrick,
I have an older shuttle and really like the feel of the gears, I also have an older HST and really like the accuracy. But it sounds like shuttles have come a LONG way from reading your post. A LONG way. I knew HSTs did but did not know shuttles did.
/ HST vs shuttle #93
HST does indeed require or use, quite a bit of HP. Depending where in its range its being operated, they run in losses of 10 to over 20%. These high losses is why we can't use Hydro UTV's in our snow industry. Just the same, for loader and other dirt work, we are looking to purchase HST tractor. Let me add, a geared transmission uses less than 5%.
Patrick,
/ HST vs shuttle #94
Fuel savings for the HST VS Gear argument for the average compact utility tractor owner is a non-issue, so don't let anyone scare you off with talk of excessive fuel usage. Here's why...
If you're a typical compact tractor owner, you're only going to put 50 hours of usage on your machine in a year. If the geared machine uses 1 gallon per hour, that's 50 gallons of fuel a year. @ $3.00/gallon, that's $150 per year in fuel cost. If the HST uses 20% more fuel, that's an additional 10 gallons and $30 more for the entire year.
Also, I read this talk of HP losses on HST quite often on TBN and usually reply with this.... HP is HP, no matter what produces it, and if you have a tractor rated at 35HP at the PTO, it puts out 35HP at the PTO, and if it's rated for 35HP at the drawbar, it pulls 35HP at the drawbar.
So, get a tractor that specs out with enough PTO or drawbar HP to complete your tasks. Same thing applies to either gear or HST. Get the machine that you are most comfortable on, that is rated to do the work you need to do, and don't worry about HP losses through the transmission or fuel economy.
/ HST vs shuttle #95
Patrick,
I would expect that HST would use more power than direct drive gears. And for those who normally run their tractors at full RPM under load it could be noticible - or maybe not. I'd like to read some studies on HST efficiency before passing judgement on power sacrifice. Or on longevity for that matter.
However, one efficiency advantage of HST that doesn't get mentioned enough is that the HST transmission is always in exactly the right gear to develop peak engine torque. The gear ratio can't help but be right because that is the way HST works. It's like a gearbox with an infinite number of gear ratios. And I suspect that the multirange HST trannys are even more efficient.
Even if the research shows that HST is less efficent everywhere - which I doubt - it sure is convenient and friendly to work with. Particularly on hills.
rScotty
/ HST vs shuttle #96
Sadly, many are designed with all pedals on right side. Have to be agile.... :(
/ HST vs shuttle #97
Yep, gotta agee. My Kubota HST+ is designed that way. Both brakes and the HST are on the right. Only the clutch is on the left in my Kubota HST
I think the layout got to be that way because in a car it is typical to work the brakes and accelerator with the right foot and use the clutch with the left. So the designers - who maybe have never driven a tractor - just copied the automobile layout without thinking about why it was that way.
Because what the tractor manufacturers overlooked is that in a car a person won't be using throttle and brakes simultaneously - where in a tractor they will sometimes. Or at least we used to. Back in the days when most tractors were 2wd, using the wheel brakes was about the only way to get the front of the machine to turn instead of just pushing dirt. Luckily using brakes and throttle together is not required as much as it used to be now that we have 4WD with sharp turning radius. But the ability is still needed and used.
As ovrszd says, it requires agility.
I think every person who has ever weighed in on foot pedal position agrees that the layout would be a lot better if the brakes were on the left next to the clutch. And moving the brakes would give space on the right to move the HST to a better - more central - position as well.
I wonder how long it will take manufacturers to notice.
Has anyone done those pedal modifications to their Kubota? 4Shorts?
rScotty
/ HST vs shuttle #98
Many HST tractors now do not have a clutch. That leaves room to put the brake pedals on the left.
/ HST vs shuttle #99
There should be two directional pedals on the left, and split brakes and a throttle pedal on the right, as well as the differential lock operated by my right heel, like my IH2500b had. I loved that layout.
/ HST vs shuttle #100
Very few if any compact tractors list draw bar HP that I remember seeing. So hard to say if there is a difference in draw bar HP.
Generally see some PTO HP different between HST and gear listed in the specs in the same make/model.
Bale Ring (A66408)
Bale Ring (A66408)
John Deere 8320R (A64126)
John Deere 8320R...
2015 Mack Granite GU713  Tri-Axle Dump (A62613)
2015 Mack Granite...
2020 Case TV370B (A64126)
2020 Case TV370B...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2019 CHEVROLET...
2017 International Prostar 122 Day Cab (A62613)
2017 International...
