HST vs shuttle
   / HST vs shuttle #131
Moss List - My Version
- Gardeners prefer a tiller over a plow - HST wins over Gears.
- Lawn mowers have to vary in ground speed often - HST wins over Gears.
- Field and Crop work - Gears win over HST
- FEL work in tight quarters - HST wins over Gears.
- Dragging logs out of the woods - Gears win over HST
- Many homeowner tasks will benefit from Gears over HST
- Many homeowner tasks will benefit from HST over Gears
I concur. :)
   / HST vs shuttle #132
I don't see any homeowner tasks benefiting from gears, but to each their own. ;)
Why do some people prefer shifting over HST in close quarters in the woods? I find myself constantly changing speeds and direction when finagling trees from between other trees in the woods with the tractor, and controlling speed and direction with my feet/foot (depending on machine) while keeping one hand on the steering wheel and the other on the joystick or 3pt controls.
Having to constantly move a hand from one control to the other becomes tedious, and then you have:
clutch, shift forward, clutch, shift backward, clutch, shift forward, clutch, shift backward,clutch, shift forward, clutch, shift backward, clutch, shift forward, clutch, shift backward,clutch, shift forward, clutch, shift backward, clutch, shift forward, clutch, shift backward,clutch, shift forward, clutch, shift backward, clutch, shift forward, clutch, shift backward,clutch, shift forward, clutch, shift backward, clutch, shift forward, clutch, shift backward,clutch, shift forward, clutch, shift backward, clutch, shift forward, clutch, shift backward,clutch, shift forward, clutch, shift backward, clutch, shift forward, clutch, shift backward,clutch, shift forward, clutch, shift backward, clutch, shift forward, clutch, shift backward,clutch, shift forward, clutch, shift backward, clutch, shift forward, clutch, shift backward,clutch, shift forward, clutch, shift backward, clutch, shift forward, clutch, shift backward,clutch, shift forward, clutch, shift backward, clutch, shift forward, clutch, shift backward,clutch, shift forward, clutch, shift backward, clutch, shift forward, clutch, shift backward,clutch, shift forward, clutch, shift backward, clutch, shift forward, clutch, shift backward,clutch, shift forward, clutch, shift backward, clutch, shift forward, clutch, shift backward,clutch, shift forward, clutch, shift backward, clutch, shift forward, clutch, shift backward,clutch, shift forward, clutch, shift backward, clutch, shift forward, clutch, shift backward,clutch, shift forward, clutch, shift backward, clutch, shift forward, clutch, shift backward,clutch, shift forward, clutch, shift backward, clutch, shift forward, clutch, shift backward,clutch, shift forward, clutch, shift backward, clutch, shift forward, clutch, shift backward,clutch, shift forward, clutch, shift backward, clutch, shift forward, clutch, shift backward,clutch, shift forward, clutch, shift backward, clutch, shift forward, clutch, shift backward,clutch, shift forward, clutch, shift backward, clutch, shift forward, clutch, shift backward,clutch, shift forward, clutch, shift backward, clutch, shift forward, clutch, shift backward,clutch, shift forward, clutch, shift backward, clutch, shift forward, clutch, shift backward,clutch, shift forward, clutch, shift backward, clutch, shift forward, clutch, shift backward,clutch, shift forward, clutch, shift backward, clutch, shift forward, clutch, shift backward......
all day long.... no thanks.
   / HST vs shuttle #133
I like doing loader work with my shuttle. I can unlike the brakes and pivot on one wheel in tight areas. Or when trying to get that maximum bucket full, in low range with the hand throttle powered up, I only have to worry about coordinating the FEL - the wheels will just spin if I push in too hard - no risk of stalling out - then it’s just a switch between high and low range to travel between scoops and dumps. It’s quite quick and efficient.
I used to use my uncle’s Kubota with HST; it was fine for loader work, but I can’t do a direct comparison because my Kioti has about twice as much hp.
   / HST vs shuttle #134
When I grew up within the ag business, HST was just starting to show up in tractors, so I have quite a few hours with geared tractors. In the thousands of hours range and doing loader work would be among this. No HST tractor on our operation. A few years ago, we rented a 35hp HST tractor for the summer to do loader work. I was amazed just how easy it was to operate this rented HST for doing loader and other small space operations.
   / HST vs shuttle #135
Here's a video from Messick's that shows a glide shift. Basically, this is a gear transmission that operates the clutch for you. It would be great for constant speed things like mowing large areas where speed changes aren't frequent. But they say most people doing loader work, frequent speed changes, choose HST over geared transmissions.
   / HST vs shuttle #136
In the woods, I regulate my speed with the foot throttle, and I like the idea of starting out at a low rpm to lower the hp and control wheel spin to get the load going. Many times I'm looking back and I can move my feet where I want to get turned around to see what's happening, and the load keeps on, keeping on.
I have no idea why some think you have to keep shifting all the time? Sounds like they need to cut down a couple more tree's so they can safely get around in their wood lot. lol
As for gardens, I could pound my soil into dust with a gear drive, but I choose to "preserve the soil structure", so gear drive or whiner drive, I would choose the same speed to make the best soil I can...
SR
   / HST vs shuttle #137
Our L3830 has a Glide Shift Transmission. It works well, but for close quarters work, I will take a HST any day of the week.
Aaron Z
   / HST vs shuttle #138
SR
I can see your points. Our woods are relatively young, with most trees being 12" and under. However, there are probably 10% large, mature trees that have to come out eventually because they shade out the new growth; around 5-600 mature trees. Also, the mature trees tend to get storm damaged easily and tipped over, so they have to come out or they rot on the ground (which isn't bad for the forest floor, but they sometimes block the trails). We don't want to cut down the young trees, so we snake out the large trees between them carefully, which requires lots of speed and directional changes. I don't want to clutch or shift all day long. Even if it was clutchless, I don't want to shift forward/reverse all day long. It gets old, fast.
   / HST vs shuttle #139
When your driving some distance, or just pulling a trailer, NOTHING beats a gear transmission. Sometimes I have to look to see what all the noise is about, the thousand or so feet away on the road, and see it's some little Hydro CUT screaming away heading down the road.
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
2015 Volkswagen Jetta Sedan (A55758)
2015 Volkswagen...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
2012 Western Star Trucks 4900 SA Truck, VIN # 5KJJALDV0CPBE2239 (A57453)
2012 Western Star...
2015 Freightliner Derrick Digger (A55973)
2015 Freightliner...
2019 Ford F550 (A55973)
2019 Ford F550...
