HST Temp Readings
/ HST Temp Readings #1
dieselsmoke1
Platinum Member
Eastern North Carolina
Mahindra 2810HST
Been lots of discussion regarding HST operating temps, so I took some sample readings with an IR temp reader this morning.
Test Conditions:
Ambient: 82 f, overcast
Tractor: Mahindra 2810HST
Work: 5' Bush Hogging in grass, average density, 8" typical, 16" in spots
Terrain: Rolling with a couple of steep banks
Load: Medium at approx. 4mph, slower in heavy areas, 2500 / 540 rpms
Duration: 1 hour / 2 hours, Both sets of values virtually identical
Tranny Case, hottest spot in rear: 159 f
Hydrocooler In: 149 f
Hydrocooler Out: 142 f
Tranny Filter: 143 f
Engine Block: 178 f
Radiator In: 158 f
Engine Oil Filter: 162 f
Dash Temp Gauge: Slightly less than center mark
I make no claims as to the accuracy of these numbers, just gave it my best shot and thought I would share them for discussion.
/ HST Temp Readings #2
Wonderful post! Nice work. Temps seem reasonable.
When it cold, do it again! I would love to see the numbers when it is freezing outside. And where and how much and what type of IR gauge did you get?
Bob
/ HST Temp Readings
Doc_Bob said:
And where and how much and what type of IR gauge did you get?Bob
Thanks. The IR is a Raytek Raynger ST, circa 1999. Belonged to a buddy who is a mainteance mechanic. He bought a new snazzy one and retired this one to the cabinet. I horse traded some cabinet work for it. Tested it side by side with his new one and readings were good.
/ HST Temp Readings #4
Hmmm. It seems like there is more cooling from the lines running to the oil cooler than from the cooler itself. Someone with cooling problems could almost plumb in several feet of copper line or something like downline of the cooler. Kind of like an Appalachian Aboriginal Alcohol condenser.
/ HST Temp Readings #5
Nice! Sounds like $$$$$.
Bob
/ HST Temp Readings
There was a lot of variation down the line from the tranny. The hottest spots were at the tranny out fitting, of course, and where the tubing passes within about 1.5" along the side of the crank case. A little shielding there would probably be worthwhile.
/ HST Temp Readings #7
Did your meter let you focus just on the oil line or might you have gotten some false data from the crankcase behind it, too?
/ HST Temp Readings
I tried to take the readings from the lines, can't say how successful I was. The meter has a built in laser sight and specs the read area at 0.8" @ 6". I was reading at about 4". I could see the readings spike up when the laser moved from the lines to the case.
Next time I'm running, I'll check again with a temporary shield behind the lines.
/ HST Temp Readings #9
Nice job! There's only one question/request I have. Can you get some readings on your main engine mounted hydraulic pump? How about when you run the 3PH up and down so the pump is producing pressure to the system instead of working into an open-center system? I'd like to know what the temperature rise is from the inlet to the outlet of the pump. I'd guess less than 5ºF, but I could be wrong. There will probably be some thermal lag while everything heats up too. It may be tough to get an accurate reading.
/ HST Temp Readings
Dang, I should have thought about that. I'll check it on my next run.
/ HST Temp Readings
Took more temp readings today. Work and load similar to previous except add intermittant FEL work. Ambient was 82f and overcast on first readings, 92f and bright sun on this test.
Tranny case - hottest spot 167f vs. prev. 159f
Hyd pump under load in 176f
Hyd pump under load out 179f
Tranny filter 157f vs. prev 143
FEL valve 159f
Engine Oil Filter 175f vs. prev. 162f
Bushhog gearbox 122f
Looks like ambient plays a pretty big role in the system's ability to cool itself.
/ HST Temp Readings #12
Great info!
Bob
/ HST Temp Readings #13
Nice job, Dieselsmoke. It's interesting that the hydraulic pump is the "hot spot" in the hydraulic system and the whole tractor. Even engine coolant doesn't get any hotter than that. Ambient temperature also seems to have had a dramatic effect. The real world numbers sure tell a story.
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
TRUCK RAMPS (A64556)
2019 Ford F-550 4x4 Altec AT40G 40ft. Insulated Bucket Truck (A64556)
2019 Ford F-550...
2010 PETERBILT 384 (A65643)
2010 PETERBILT 384...
72in. Skid Steer Bucket (A65640)
72in. Skid Steer...
Lot of Allmand Light Plant Fixtures - Halide Assemblies (Bulk Lot) (A63689)
Lot of Allmand...
