HST steering
   / HST steering #1
BER
Bronze Member
SW. Indiana
MF1235 HST MFWD
Can the HST steering be damaged when turning the steering wheel while the engine is not running? I have done this a time or two so to reach a grease nipple. It sure is hard to turn without the engine running!
   / HST steering #2
I really don't believe that you can damage your power steering by attempting to turn the steering wheel while the engine isn't running, and I'm sure someone will correct me if I'm wrong here.
That said I'm not sure why you would need to, as it's very easy to start the engine for a short burst to set your wheels where it's easiest to do your lube then turn the engine back off to lock the wheels in position.
   / HST steering #3
My manual for my JD4100 actually says that it is specifically possible to steer the tractor when not running during towing or when loading on a trailer, but that the force required may be higher.
- Rick
2024 Greatbear 72in Vibratory Roller Skid Steer Attachment (A51691)
2024 Greatbear...
2019 John Deere XUV 825M S4 Gator 4x4 Utility Cart (A51691)
2019 John Deere...
1997 International 9300 Day Cab Tractor (A52384)
1997 International...
2013 Ford Fusion Sedan (A51694)
2013 Ford Fusion...
2009 Trail King TK110HDG-523 RGN 66 Ton Tri-Axle Lowboy Trailer (A52377)
2009 Trail King...
