HST slow to neutral
/ HST slow to neutral #1
ZackaryMac
Nova Scotia, Canada
B6100 HST-E, T1600, Case 1818
Mosy of the time when doing a lot of forward/reverse work, I find the HST not returning to center or neutral on it's own. It doesn't feel like a consistant decrease in speed, as the damper would do if gooped up, but more similar to a worn spot somewhere in the system. The pedal comes pretty close to middle, but the speed is about 20% somethimes. It makes for interesting work when you release your pedal to stop and it keeps on moving. Of course this usually happens when I'm near something I can break or fall in to. /forums/images/graemlins/crazy.gif
Funny thing is, when the engine is stopped and I try the pedal, it moves freely and returns to center quickly. No notchiness at all.
Has anyone else ever experienced this? And if so, what was the cause?
Thanks. /forums/images/graemlins/grin.gif
/ HST slow to neutral #2
Try cleaning the pedal pivot with some brake cleaner spray and then re-lube. I was having problems with my hydro pedal on my BX and this resolved the problem. I believe that the lube attracts the dirt and then it starts to get sticky. Cleaning and re lubing worked for me, and it was about a 5 minute fix. Occasionally, the pedal sticks, but that is a quirk of the BX series. Some work better than others and there is no rhyme or reason as to who is going to have problems and who isn't.
/ HST slow to neutral #3
I have the same problem with my BX22. I did the cleaning, spraying, lubing etc. To date, nothing has worked. So the BX is going to the dealer to fix the slow moving pedal and the Fuel Sending unit leaking.
I know how it feels to stop and it keeps moving...Wonderful feeling. Nice when working by the garage and almost go through it!
</font><font color="blue" class="small">( I know how it feels to stop and it keeps moving...Wonderful feeling. Nice when working by the garage and almost go through it! )</font>
Exactly! And for some unknown reason, when this happens, my foot is just above the HST pedal, and twice now I've stomped on it in panic mode, brain thinking BRAKE, foot, having no brains, follows orders without question. More acceleration just seems counter-productive at this time.
The HST pedal has a grease fitting in the end of the pivot shaft, so lube isn't a problem. I keep everything well lubed. I'm thinking that if this tractor was used a lot for mowing as I was told, it was kept near a constant speed, and wore a small detent somewhere that I can't readily see. I know I have to find and fix, though. Sooner or later it's gonna cost me, one way or another. /forums/images/graemlins/frown.gif
Thanks for the responses, guys. /forums/images/graemlins/wink.gif
/ HST slow to neutral #5
The HST pedal connects though a linkage arrangement of rods and levers, obviously, to the tranny. There is a neutral adjustment somewhere in that linkage so it can be set to return to the neutral position. A Kubota dealer should be able to tell you how the adjustment works on your particular model.
If there is rust or other crud in the area of the linkage, it could be binding or maybe it's just worn. Hopefully your problem is something external like that, which would be simpler (and cheaper!) to fix than something in the tranny itself.
Well, I took the cover off tonight and discovered the pedal is connected to a cam on the side of the transmission, and on the bottom of this cam is an inverted "v" where a lever with a spring at one end, a small wheel in the center, and a bushing at the other ride against this cam. The pivoting end of this sping-loaded arm has an adjustable eccentric. After taking it apart, I find the bushing is kind of tight, so I gently clean and ream it to free it up a bit. Synthetic lube, re-assembly, and adjustment of the eccentric later, it feels better. Out I go again to push dirt with the 3ph blade. Works great, until I have a load against the tractor, and it will sit there and spin the wheels against the load until I tap the HST pedal. The pedal itself is absolutely NOT sticking. My next plan of attack is to put a slightly stiffer spring on the return lever, as I feel it may be worn inside the tranny and so needs more "return" pressure to overcome this.
It came to the point tonight that either I fix it or ruin the tractor, or worse. It's rarely a problem with mowing, however it's not right or safe. I'll find a solution somehow! /forums/images/graemlins/tongue.gif
/ HST slow to neutral #7
I looked at a used B21 and it had this same problem. The seller said it was a minor adjustment. Because the B21 also had a few other problem, I decided to not buy it.
Later, at a rental yard that rents lots of Kubota products, I talked to the yard owner and he said the HST creep was a problem with all his Kubotas. And, that it could be adjusted out. But, it didn't stay adjusted for very long.
Now in that busy rental yard, not very long probably means every several hundred hours. (He turned his tractors at 2,000 hours which they rolled up in 2 to 3 years.) He had 10 to 15 Kubotas, so, he was probably adjusting several a month. I would suspect, that a homeowner user wouldn't have to do this but every several years. He kind of indicated they ran well for the first year, then required periodic adjustments.
Even so, I still bought a new HST Kubota.
Bottom line--once you fix it it should last a while [with moderate personal use]. Unless you are a contractor, in which case, it says you should think about getting a new tractor.
Of course I didn't ask what the adjustment was. /forums/images/graemlins/frown.gif I didn't have a tractor at that point. /forums/images/graemlins/smirk.gif
I put a heavier spring on the return arm, and it looks like this cured it. It will stop so fast now when I take my foot off the HST pedal, it'll drag the back tires. That's fine. At least when I say Woow, it Woows. /forums/images/graemlins/grin.gif
The pedal is harder to press now, perhaps a bit too hard for maximum speed, so a slightly softer spring may be in order, but at least I'm in the right, and safer, direction.
Result: Pucker factor greatly reduced! /forums/images/graemlins/tongue.gif
/ HST slow to neutral #9
Just picked up my BX22 today from the dealer. It was in for the similiar "stuck pedal" syndrom. My repeated attempts at spot lubricating didn't seem to help. The dealer dissassembled the entire linkage, cleaned, lubricated and reassembled. One noted item was some factory paint that appeared to be binding one of the link points (I don't know exactly which one). It works great now. We'll see if it stays that way.
/ HST slow to neutral #10
Great stuff guys. After 350 hrs on my BX, I'm pretty used to the HST "stick" but would love to get it taken care of. I like the spring idea, as I've tried just about everything else over the course of 3 years or so. The pedal stuck after the first week I had it and instead of running it to dealer I decided it was a tractor and I'd deal with it.
/ HST slow to neutral #11
Well boys, I went and talked with Jim at Emerich sales and he fixed my leaking fuel sending unit and my slooooow to return pedal.
Took about 10 minutes for the pedal and about 1.5 for the sending unit to be replacing. He showed me how to adjust the pedal linkage on the spring to get a "harder pedal" and how to adjust "the adj plate" to return to center. Boy, it stops like mad now. Gary, did a GREAT job. All the spraying of this and that did ZERO. I wish they had this adjustment in the book!
the sending unit was easy except for the billion bolts, nets etc to remove. Even got my filters replaced while he had it apart.
I will post a quick and dirty webpage if someone wants some instructions on how to do it.
/ HST slow to neutral #12
Yes Mike,
I would love to get the info on the adjustment plate and linkage for the slow hst pedal. I have the same issue and have just been living with it. Thanks for taking the time.
/ HST slow to neutral #13
I will second that motion for a web page... thanks.... Junk...
/ HST slow to neutral #14
I webpage will be up by Sunday Night. Keep checking since I might get some free time this Saturday with the rain....unless I am messing with the reef tank or shotting.
Link is below.
http://home.comcast.net/~Burnickas_guns/BX_pedal/pedal.htm
*** update --It should be up with 1 hour....I can't help myself!
/forums/images/graemlins/smile.gif
/ HST slow to neutral #15
Your wish is my command...Page is up. /forums/images/graemlins/smile.gif
/ HST slow to neutral #16
Thanks a bunch Mike. Very well described. I'll try it this weekend and post back if it fixes my pedal as well.
/ HST slow to neutral #17
Thanks for the post! I'll see if I can apply it to my MF GC2300 which suffers from the same problem. (Actually, I've come to consider it the "free cruise control" that so many of you are paying extra for these days...)
/ HST slow to neutral #18
I would try the spring one and see how that works. Do not do both at the same time. Then try the plate adj after. Only need to move small amount.
/ HST slow to neutral #19
This Spring adj works on a GC2310 MF.
for the front now I am looking to tighten the reverse.
I f it never gets better this sure help me
Thanks /forums/images/graemlins/smirk.gif
Well it's been about 15 hours since my spring transplant repair, and it still works 100%. No more heart stopages. The stopping is abrupt if you just pull your foot from the HST, so a little gentle-releasing makes decelerating smooth. Since I don't hold the pedal flat-out in either range normally, the increased effort to push the pedal goes un-noticed. I'm just glad the dang thing reliably stops when I want it to. /forums/images/graemlins/grin.gif
YANMAR VIO35-6A EXCAVATOR (A63276)
YANMAR VIO35-6A...
New/Unused 16 Gallon Landhonor Vacuum Cleaner (A65583)
New/Unused 16...
New/Unused 3-in-1 Quick Attach Frame (A65583)
New/Unused 3-in-1...
Kubota Industrial Turbo Diesel Engine - Tag Missing - Pump Takeout - Approx. 80-85 HP Class (A63689)
Kubota Industrial...
Landhonor Skid Steer Bale Spear, Dual Spear  (A62679)
Landhonor Skid...
2014 Bobcat E63 (A64126)
2014 Bobcat E63...
