HST or gear drive ?
   / HST or gear drive ?
Re jinman,In my area, yes gear drive is the preference on the compacts so far ,I guess it comes down to individual choice or what the dealers show customers.Got to agree with Richard about HST on lawnmowers, the only way to go:) Kerry.
Re:MChalkley,I think you could be right,I wouldn't like to place any bets. The guy I work for is looking at a new 250hp Fendt,WOW!,bloody nice bit of gear, it's between a N/H and the Fendt,hope he gets the Fendt. I'll let you know what he buys. Kerry.
   / HST or gear drive ? #33
Found this technical bulletin on the Firestone site. Basically say everything you have said MarkC. It adds some explainations what over/under/proper inflated tires may cause. This technical bulletin talks about the lead/lag on the Fwd system on tractors and how it can contribute to tire wear. Something you talked about a while ago. Oops! of topic again for me.
One more off topic question MarkC, Do you have problems with the tires slipping on the rim in high traction, heavy pulling situations running a low pressure. I have seen this on a tubless tire/rim setup on a 2wd garden tractor. But with a tube couldn't it shear the stem off?
Derek
   / HST or gear drive ? #34
Derek - Nice link. It's true - if you have a slippage problem and you're using a tube, you can shear the stem off. I've never had any problem with slippage, though. Usually, if you do, you've got other problems, too, it's not just because you're running low pressures. For one thing, you have to make sure the tires are properly seated before setting your final pressure. For another, you have to make sure the wheels are the right profile and width. You can get away with using a rim on the narrow side, but never one that's too wide. If you have a slippage problem, you can usually trace it back to using the wrong wheel. My rear wheels are the original ones that came on the tractor - which means that, even though the tires are 5" wider than stock, the wheels still work fine. You can't go the other way, though.
MarkC
2117 (A58376)
2117 (A58376)
500 BBL FRAC TANK (A58216)
500 BBL FRAC TANK...
Giyi Pile Hammer (A57149)
Giyi Pile Hammer...
DECORATIVE METAL GATE (A58214)
DECORATIVE METAL...
2012 FORD F450 XL SUPER DUTY TRUCK (A51406)
2012 FORD F450 XL...
Dodge Charger (A56859)
