Calibration process as gleaned from the service manual. I take no responsibility for the accuracy here (I don't have access to any updates to the manual, in which case if there are any updates they are not reflected here).
Calibration mode activation
• With the brake pedal depressed, press the CAL
switch and hold the ignition switch in the ON posi-
tion for approx. 2 seconds to enter the calibration
mode.
• The lamps come on in the following order: N->L->N
->M->N->H->N->L->N->M->N->H->N. Then, the “N”
lamp comes on.
Remark
• If the calibration mode is abnormally activated,
the lamp “N” comes on.
Upper limit setting for forward/
reverse driving pedal
• Check the upper limit of the forward/reverse driv-
ing pedal. With the pedal released, press the “NO
STALL” switch (1) to the ON position and set the
cruise switch (2) to the ON position once.
• The “N” lamp (1) goes off and the “CAL” lamp (2)
comes on.
Remark
• If the limit is correctly set, the “N” lamp goes off
and then the “CAL” lamp comes on.
• If incorrectly set, the cruise lamp blinks.
Lower limit setting for forward/
• With the forward/reverse driving pedal depressed to
its deepest position, place the speed limit switch
to the ON position and set the cruise switch to
• The “CAL” lamp goes off and the “N” lamp
comes on.
Remark
Finishing setting
• After performing the steps described above, make
sure to set the speed limit switch (1) to the OFF po-
sition and turn the ignition switch to the OFF posi-
tion to complete the calibration.
