HST (hydrostatic) forward/reverse pedals suddenly stiff and won't go normal speed
   / HST (hydrostatic) forward/reverse pedals suddenly stiff and won't go normal speed #1
MMist
Clatsop, OR
Mahindra 3215 hst
Mahindra 3215 hst with hydrostatic shift. Forward and Reverse pedals, and the speed of the tractor, were working just fine last weekend.
Today, the heel pedal (reverse) was very stiff, almost had to stand on it, and even then the tractor barely crawled. Tried forward and fine, not stiff, regular speed as expected.
I lubed the zerts, tried again, now the front pedal has so much resistance and very slow forward momentum.
Checked the fluid level, clean and full...let it idle a bit, now it's tough in both positions...although it seems to free up in one direction occasionally.
Tractor had a full service last winter and haven't had the problem before.
Ideas?
Regards, MMist
   / HST (hydrostatic) forward/reverse pedals suddenly stiff and won't go normal speed #2
I've had a similar problem when working in brush - often a stick or some other trash lodged in the linkage. Perhaps you should follow your reverse linkage to make sure nothing is bent or jammed.
   / HST (hydrostatic) forward/reverse pedals suddenly stiff and won't go normal speed #3
I have had the same experience as FritzWH. It only takes a little-bitty stick jammed in the linkage. Can also happen when bush hogging in the open. A lot of debris gets tossed about along with dust and cut material.
   / HST (hydrostatic) forward/reverse pedals suddenly stiff and won't go normal speed #4
Did you resolve the issue? My 3215HST is have similair issue. Reverse is fine. Forward is half speed. I can stand on pedal and make it go(sort of normal speed). Checked linkages and I can't find a problem.lubed zerts.
Its working but not normally.
2014 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A54313)
2014 FREIGHTLINER...
2009 Kaufman Gooseneck Trailer and 10K Hydro-Blast (A50860)
2009 Kaufman...
John Deere 2640 2WD Tractor with 146 Front Loader (A55218)
John Deere 2640...
UNUSED Heavy Duty Ratchet Strap Set (A53117)
UNUSED Heavy Duty...
