HST: how do you reverse with your foot on the brakes ?
   / HST: how do you reverse with your foot on the brakes ? #31
Back in the old days growing up on a farm we had narrow front ends (sometimes called tricycle type even though there were 2 front tires) and it was common to use turning brakes. Then I worked for 22 years on combines and when picking corn made heavy use of turning brakes to make a 180 from picking one set of rows to going back on the other. Hydro was no problem because every combine I used had a hand propel lever. The next 21 years on construction equipment all our hydros had propel lever. My Kubotas with the pedal have not been a problem until this year. I have been discing some rough fields and all too frequently have had 1 front and 1 rear spinning in air. All I would need is a bit of turning brake on the rear that is spinning to put power to the other rear with good traction but it almost always seems to kick the cruise off. Maybe I am accidentally hitting the back side of the pedal when I reach for the turn brake. But other than that, I have never had use for any kind of brake on my hydro tractors except for parking brake.
   / HST: how do you reverse with your foot on the brakes ? #32
It is easier to use the brakes and HST if they are on opposite sides. One foot for HST, the other for brakes. I have a flat deck too; it is just so much easier. FWIW I do not have a clutch either...
I'm not sure why which side the brakes are on (left vs right) would be an issue with the GL tractors. The deck is flat, I don't think I would want anything with a hump. Using your left foot to operate the brakes is not hard at all. On my Case backhoe the brakes are in the middle (and no clutch).
   / HST: how do you reverse with your foot on the brakes ? #33
No, you set the cruise AND the hand throttle. The HST on most tractors(CUT's) lets you have variable speeds at any throttle setting(lest you lug it, and need more throttle). The cruise control, will let you effectively "lock" the HST at a specific speed.
This is true for my old Kubota HST and my newer NH HST tractor.
On my old Kubota, you set the throttle for the power required for the task at hand. Then, when you press the HST and get to the speed you want, you set the cruise. Then, your foot is free from the HST pedal and you can now work the brakes for "steering" control. It does work; it is just cludgy compared to other modern tractors.
For comparison, my current NH(and most JD's I believe; not sure of other brands) has brakes on the left, and HST on the right. Once I set the rpm for the task at hand, I can vary the steering using the individual brakes if the front is light or traction is limited. I can also vary speed by how much pedal I give the HST.
On my Grand L, the "cruise control" is a hand lever that you can use in lieu of the HST pedal to "accelerate" and it stays where you leave it. So you can place the foot HST pedal where you want it and advance the lever to maintain that position or advance to that position using the hand lever making use of the turning brakes going forward relatively easy.
I do agree however it is easier with HST pedal and brakes on the opposite side. If I needed turning brakes, that would be my preference. I have just found in over 50 years of operating a variety of tractors with brakes on the left and right as well as straight non synchro gear, synch shuttle, hydro shuttle and HST for what I do with my CUTs, steering brakes are a non issue. As mentioned, I use them on our M8540.
As a side note, one of the men who rents our row crop land and is a good friend fixed a washout on a hillside on our property with a John Deere ehydro 4610 using a FEL and hydraulic back blade. It would have taken me twice as long unless I brought the 8540 up.
   / HST: how do you reverse with your foot on the brakes ? #34
It is easier to use the brakes and HST if they are on opposite sides. One foot for HST, the other for brakes. I have a flat deck too; it is just so much easier. FWIW I do not have a clutch either...[/QUOTE]
I sure wish Kubota would get rid of the clutch too.
   / HST: how do you reverse with your foot on the brakes ? #35
The cruise on the "deluxe" B series Kubota's is different, and much nicer for using brakes, etc. With that cruise, you can push the cruise lever ahead from a stop to control your speed instead of bringing it up to speed with the HST pedal, and then locking the cruise. In tight areas you can run the tractor just using the crusie lever, and have full access to the brakes. On my road to the shed, I am there before I can get the cruise set so it is pretty useless ( short drive) when pushing snow with the loader bucket, and the bucket is steering the tractor.
   / HST: how do you reverse with your foot on the brakes ? #36
Interesting. That is a direct echo of what I said with 12 years of using a nicely set up "B" series.
My wife sometimes says I don't change much also! :D
I regularly use the turning brakes on our antique Super M and used them all the time on the TO-20 and others long ago, but with our work these days they just doesn't seem necessary very often. In different circumstances though, I could see how that pedal setup could be a pain.
   / HST: how do you reverse with your foot on the brakes ? #37
I don't think they had a Deluxe option when my old B8200 was made('85/86). Maybe the HST was the Deluxe option, but otherwise it was pretty plain. For cruise, it had a locking lever on the lower dash.
I got to visit it a couple weeks ago. It was good to see an old friend :D
   / HST: how do you reverse with your foot on the brakes ? #39
So far that has not been an issue for my NH. But, it is independent PTO, with a hydraulic clutch. It though, is more comparable to a 40hp L series though, not B series. I have only used the 6' rotary mower though; not a real big pto load.
Not me I love having it for gently starting big pto loads.
   / HST: how do you reverse with your foot on the brakes ? #40
I can start my PTO gently with my lever just as I do on my BX2660 and M8540. I did it with the clutch when I first got my L5030, but now just use the lever as per page 47 of my Operator's Manual.
I see where the newer GL models have gone to a button engagement, so I am not sure how that works as to gentle engagement.
Our Case CX80 had a notch in the engagement slot where you placed the lever for a few seconds to allow the PTO to spool up before full engagement which I really liked.
Unused 2025 CFG Industrial H15R Mini Excavator (A59228)
Unused 2025 CFG...
2008 DOOSAN G25 GENERATOR (A58216)
2008 DOOSAN G25...
2018 FREIGHTLINER CASCADIA SLEEPER (A59575)
2018 FREIGHTLINER...
2013 Freightliner M2 106 16ft Stakebody Flatbed Truck with Liftgate (A55852)
2013 Freightliner...
2005 Chevrolet C4500 Altec Bucket Truck (A56858)
2005 Chevrolet...
207278 (A52708)
207278 (A52708)
