HST goes "weeky-weeky-weeky"
   / HST goes "weeky-weeky-weeky" #11
Re: HST goes \"weeky-weeky-weeky\"
cornfed,
Have'nt tried the shim material before, usually replace the hubs with the updated version, they tend to stay tighter. However if you grease up the axle then slide the hubs back on it usually solves the problem (I use anti-sieze, lasts a bit longer). That shim material may be a real treat trying to install.
(2) STAMPED INTERNATIONAL WEIGHTS (4) FORD WEIGHTS (A52708)
(2) STAMPED...
1R PLOW, 3PT (A52708)
2012 BIG TEX PIPE TRAILER (A55745)
2012 BIG TEX PIPE...
2009 Chevrolet C8500 Dump Truck, VIN # 1GBT8C4B59F409922 (A57453)
2009 Chevrolet...
VICOR HAY CUTTER (A58214)
VICOR HAY CUTTER...
New/Unused CFG Industrial MH12RX Mini Excavator (A57453)
New/Unused CFG...
