HST fluid change on 2230
   / HST fluid change on 2230 #1
blue85
nj
kubotq 2230
When changing hst fluid on 2230 is it best to retract pistons on fel and bh to be able to remove all of the hst
thanks joe
thanks joe
   / HST fluid change on 2230 #3
Check your owners manual.....I don't believe that there is enough Hst. fluid residue in the loader and backhoe lines to be of any concern. The owners manual makes no mention of this and I didn't worry about it when I changed mine. Good question though.
   / HST fluid change on 2230 #4
   / HST fluid change on 2230 #5
There will still be hydraulic fluid in the cylinders even if you retract all of them, not to mention in the lines. Recommended change intervals take this into account.
   / HST fluid change on 2230 #6
2020 RoGator RG1300 Air Max Precision R2 Spreader (A53342)
2020 RoGator...
2015 FORD F-150XL SINGLE CAB TRUCK (A51406)
2015 FORD F-150XL...
International Acid Tanker Truck (A52377)
International Acid...
2023 New Holland CR10.90 Combine - 330 Engine Hours - 251 Separator Hours (A53472)
2023 New Holland...
ECHO GT-225 GAS WEED EATER (A51248)
ECHO GT-225 GAS...
2019 Ford Explorer SUV (A51694)
2019 Ford Explorer...
