HST filter change question
/ HST filter change question #1
Mpking
Southwest Washington
Kubota L3240HST-3, Hustler Fastrak 54" ZTR
I'll be doing the 50 hour service on my L3240 sometime in the next week or two. When I was at the dealer today buying supplies, I was picking their brains on how they minimize oil spillage when they swap the HST and hydraulic oil filters without draining the HST/trans oil. The technician from the shop said that he doesn't really worry about it since there is a valve that stops excessive oil spillage when the filters are removed on the 40 series tractors. He said most of the oil he loses is what comes out of the filter itself. This was the first I've heard of this feature. I was planning on trying the trick of putting a shop vac on the oil filler or parking sideways on a hill but maybe it's not worth the effort? What's everyone else's experience with this?
/ HST filter change question #2
It's news to me as we lost almost a gallon and had everything in place ready to pull the old ones and go right back with the new ones, one at a time.
/ HST filter change question #3
We lose no more than a quart when changing them on our L5030; we don't use suction, tilt the tractor etc.
/ HST filter change question #4
I failed to read my manual when I did the 50 hour service on my L5740. I had been following threads on this forum and remembered people talking about changing both hydraulic and hydrostatic filters. Took off the hydraulic filter and installed the new one with very little loss, easily caught in my catch pan. Then came the hydrostatic filter and a gusher. I got the filter changed as quickly as possible but had lost over a gallon. Then I read the book. It said to change the hydraulic oil and hydrostatic filter at 400 hours, and only to change the hydrostatic filter with the system drained. I am sure if you put vacuum on the filler you will lose very little oil if you do want to change the hydrostatic filter and not the oil. Not home and I can't remember if my book is for L5740s only or covers all 40 series. Mine is a L5740HSTC-3.
/ HST filter change question #5
One of my filters was a real bear to get off. Can't remember which one. The base has notches like every 90 degrees for a screw driver and hammer if needed. FWIW. Philip.
/ HST filter change question #6
I pulled the filler/ dip stick at the back of the tractor and bought a rubber cork. I didn't loose too much oil, a quart or so and I'm sure a lot of that is from the filter. Be prepared though. The HST filter has a magnet on it that could stay stuck to the tractor. If it does I don't think you can put the new filter on if it has the new magnet on it. You'll want to remove the oil magnet as it will have lots of fine metal filings on it.
Thanks Philip. The guys at the shop mentioned that as well. Hopefully I'll get it off there without too much trouble.
The magnet possibly getting stuck is the thing that has me concerned. I'm pretty sure I could swap them with minimal loss if it was simply taking one filter off and quickly putting another back on, but if I have to spend any time getting that magnet off I could end up with a bucket full of oil. Not the end of the world but I'd rather avoid it.
Thanks for everyone's advice. I'll post a quick update on how things went when I get around to doing the service.
Finally got around to putting the new HST and hydraulic filters on the other day. I decided to give parking on a hillside a try. I swapped the HST filter first with only maybe a couple ounces of spillage, most of which came out of the old filter I think. The other side didn't go quite as well. Lost 2-3 quarts. No big deal though. Sure glad I changed the hydraulic filter though, look at all those metal filings stuck on the magnet.
/ HST filter change question #10
That's a lot more iron than I expected to see! I'm glad you changed it too. :thumbsup:
/ HST filter change question #11
Pretty much the same experience I had with my L3240.The metal filings were about the same as on your magnet but nothing like what came out at the fluid and filter change,400 hours I believe.The bottom of the 5 gallon bucket that I drained the fluid into was pretty much covered with metal bits and shavings.It was a lot more than I expected but is apparently normal.I guess this is why the fluid change is important,to flush this crap out of the tractor.I am just about to the 800 hour mark and will be changing all six filters that the tractor has.I am going to try the shop vac trick on the hydro filters and see if it works,hopefully it will.
Year: 2017 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 82349 Pla... (A59231)
Year: 2017 Make...
2015 Freightliner M2 106 AWD Altec AT37G Bucket Truck (A60460)
2015 Freightliner...
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60460)
2020 Freightliner...
2019 John Deere R-4038 (A61306)
2019 John Deere...
2016 Ford F-150 Crew Cab Pickup Truck (A59228)
2016 Ford F-150...
Deutz D 2011 L03 Engine, 3-Cylinder Diesel (A63689)
Deutz D 2011 L03...
