Oil & Fuel HST filter B26
   / HST filter B26 #1
don white
South eastern Pa.
kubota B26
I have a B26 and it is due for the 200 hour oil change and HST filter change.
Did the oil change but I am wondering if I should pull the rear wheel to do the HST filter. Also should I do the vacuum trick on the filler hole? Is there a magnet on the HST filter. Don't want to end up with an oil pond.
   / HST filter B26 #2
Don't use the suction trick. The worst contaminates and water all to to the bottom or the housing where the drain plug is. The vacuum will only get most of the oil and what is leaves it the worst. Change the filter. Cheap insurance (even if the filter is not cheap).
   / HST filter B26 #3
To avoid the pond (been there more times than I want to admit):( check the capacity and make sure you have an open drain pan that is large enough to give a big area to hit when you pull the plug and has enough capacity.
   / HST filter B26 #4
I believe the "vacuum trick" he is talking about is a vacuum at the filler neck so that when you remove a filter or screen, no oil comes out.
I do not think he is refering to the vacuum pumps that change oil without removing the drain plug.
Deano
And yes Don, I would do the vacuum trick!
   / HST filter B26
Thanks Deano that is what I was talking about.
I am gonna try it but I have the feeling this is gonna be a Hey Mo hey Larry moment.
What about removing the wheel I think it is worth the effort for better access.
   / HST filter B26 #6
About to do the 200 hr service on my BX25 and also plan on using the shop vac on the filler tube trick. Wish us both luck! I didn't think about removing the tire but might do that too since I also have a skid plate to work around.
   / HST filter B26
So I changed the HST filter yesterday and all went well.
I did remove the wheel and think it was worth the effort. It was funny I had the jack out by the tractor when the light bulb went off. Oh yea I don't need the jack just a jack stand.
Didn't use the vacuum though I just parked on the side of a hill. Lost nothing but what was in the filter.
Because very little came out I had time to wipe the mounting surface off and take my time.
2023 LANDHONOR VPC-11-72W VIBRATORY PLATE COMPACTO (A51244)
2023 LANDHONOR...
UNUSED AGT H15R EXCAVATOR (A51243)
UNUSED AGT H15R...
2019 Harley Davidson 114 Police (A50324)
2019 Harley...
2007 KENWORTH T800 DUMP TRUCK (A51243)
2007 KENWORTH T800...
AGT Agrotk 680 Drop Hammer Attachment (A47384)
AGT Agrotk 680...
