HST Change
/ HST Change #1
ST98
Bronze Member
Eastern,PA
Kubota L3540
I recently purchased a 3540 and am already close to the halfway to it's first service. The manual says replace oil and oil filter at 50 hours. It also says replace the HST filter at the same time. Does anyone know if you change the transmission oil at the same time? It doesn't give a time frame in the service interval for tranny fluid change. By the way this tractor is awesome but probably gonna have to get an hd bucket.
Thanks all
/ HST Change #2
Look at your service intervals in your maintenance schedule.
You will get two for certain answers:
1. Go by the Operator Manual.
2. The first service is the most important, so change fluid, it is "cheap insurance".
There may be slight variations, but those are the two most often seen and oil/lubricant threads can get a bit testy.
/ HST Change
Understood. Just wanted to clarify my manual due to it telling me to change oil and filter and just to change tranny fluid filter.
/ HST Change #4
Yeah, it gets confusing as the manual on my L5030 showed a different schedule than on my L5740 which shows the same as yours.
By the way, I have the HD bucket and really like it.
/ HST Change #5
From other threads on this topic, I can tell you that some manufacturers and models do not require change of transmission oil at the 50-hour service, and others do. If you go with whatever your manufacturer recommends, you should be okay. If you are nervous, it won't hurt to change the transmission fluid, except your wallet.
/ HST Change #6
That is pretty much the way I see it.. On my Kubota L3400HST, it said to just change the filters at 50 hours and not the transmission fluid until 400 hours.. However my new Kioti said to change the filters AND the oil at 50 hours. So I did what the manuals said to do in each case. On the Kioti, the oil was no way near as clear coming out at 50 hours as what I put back in. ( one of 3 fluids approved in the manual). I was kinda glad I changed it out. Do what your heart tells ya. Or your pocketbook:)
James K0UA
/ HST Change #7
Read that manual agian, page 78 in mine, very detailed description.
Engine oil and engine oil filter, initial at 50hours, then every 200 hours after that.
HST FILTER and hydraulic FILTER (FILTERS only) at 50 hours, then every 400 hours after that.
Transmission FLUID (also same as HST, hydraulic, and rear end) every 400 hours. Also, front axle at 400 hours too. Per Kubota, there is no 50 hour service for transmission fluid.
Personally, I did all fluids and all filters at 50 hours.
Check you front axle fluid level, historically, they are delivered a little low.
Philip.
/ HST Change #8
I changed my engine oil and filter at 50 hours and both the hydraulic and HST filters. I only topped of the hydraulic oil to replace what had leaked out.
I can tell you this, when you remove the filter on the FEL control side oil will flow out fast. The filter has a magnetic ring to catch metal filings. The ring may stick to the filter or it could stick to the transmission. If it sticks to the transmission you will need to remove it before installing the new filter. There are threads telling how to use either a vacuum or rubber cork to slow the oil down.
Follow the manual. It will go through the process pretty well.
BTW the oil that came out of my transmission looked just like new (not that you can tell much by visually looking at the oil).
/ HST Change #9
This makes good fluid to top off or replace the old watery stuff in dump trucks/trailers or any older tractor that has really cruddy fluid when you buy it. Backhoes often are in a mess fluid wise that have some age on them and do not get used much.
/ HST Change #10
IMO, this is because there are air bubbles that work their way out. Mine was delivered a little low, then topped off, then was a little low again, then topped off, then a little low again, then topped off... and has been fine ever since.
/ HST Change #11
Personally, have a fluid analysis done. Sometimes the fluid needs changed, other times it doesn't. It depends on the environment. Clean filters doing their job adequately and not over heating the fluid, should be good.
The sniff or eye test is worthless. But in the end as stated earlier, you asked a loaded question. If in doubt, change it.
/ HST Change
That's what I saw when I read the manual. The filter at 50 hours and fluid later. Just wanted to check my lack of brain most days.
Thanks all
/ HST Change #13
With the amount of castings I've found in the first changes with two different tractors, I would change the fluid. Just cheap insurance in my opinion.
/ HST Change #14
I had read a lot of stuff on TBN before doing t he 50 hour service and neglected to read the book. Engine oil and filter okay. Hydraulic filter which is a suction filter that gets everything going through the system okay. Then I pulled the hydro filter which filters the charge oil for the hydro. Amortization oil bath. Then I read the book. Hydro charge filter at 400 hours after draining all the oil. I would say go by the boo because my tractor had a super clean system but I have seen others post pictures of unacceptable crud in their system at first change so Kubota's quality control is suspect. It might not hurt to change everything.
1761 (A58375)
1761 (A58375)
*Selling at Royal Auction Tampa, FL Location* (A59228)
*Selling at Royal...
Volvo EC220EL (A60462)
2005 SBX-5 Box Blade Tractor Attachment (A61572)
2005 SBX-5 Box...
ROTARY SCYTHE (A63291)
SQUARE FUEL TANP & HAND PUMP (A63291)
SQUARE FUEL TANP &...
