HST 2615 Glow Plug light stays on
   / HST 2615 Glow Plug light stays on #1
optimist
Sometimes it goes out 'normally', but then it may come back on constant or flash like it's got a short. I'm guessing the relay (but that's just a guess). I don't know where it is though...any other things I should check or a pointer to where the relay is would be great.
Thanks
Joel
   / HST 2615 Glow Plug light stays on #2
Thanks
Joel
The timer/relay is located under the black cover below the steering wheel, on the left side.
Ah, so the timer and relay is in one piece. That the thing labeled "NGK OGS Controller", model # S85NE? Are those still available or is this where the conversion kit is needed?
   / HST 2615 Glow Plug light stays on #4
Those are now obsolete. I just changed mine today to the new 10 second timer with different glow plugs than work with the 3 second timer. It was a very easy fix, just expensive, $200.00
Be sure to blow all of the crud away from plugs before removing. One member with another brand tractor had a temporary problem when a piece of debris got into the glow plug hole.
   / HST 2615 Glow Plug light stays on #5
Witch one replaced the S85NE
Thanks
2018 Lexus IS300 Sedan (A51694)
2018 Lexus IS300...
2015 Terex PowerScreen TrakPactor 320 Crusher (A50322)
2015 Terex...
Pro-Cut PFM 9.2 On-Car Brake Lathe (A50325)
Pro-Cut PFM 9.2...
172in Golf Ball Picker (A50325)
172in Golf Ball...
2015 FORD F-250XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250XL...
2008 FORD F-350 (A52472)
2008 FORD F-350...
