HST 2615 Glow Plug light stays on
   / HST 2615 Glow Plug light stays on #1
optimist
Sometimes it goes out 'normally', but then it may come back on constant or flash like it's got a short. I'm guessing the relay (but that's just a guess). I don't know where it is though...any other things I should check or a pointer to where the relay is would be great.
Joel
   / HST 2615 Glow Plug light stays on #2
Joel
The timer/relay is located under the black cover below the steering wheel, on the left side.
Ah, so the timer and relay is in one piece. That the thing labeled "NGK OGS Controller", model # S85NE? Are those still available or is this where the conversion kit is needed?
   / HST 2615 Glow Plug light stays on #4
Those are now obsolete. I just changed mine today to the new 10 second timer with different glow plugs than work with the 3 second timer. It was a very easy fix, just expensive, $200.00
Be sure to blow all of the crud away from plugs before removing. One member with another brand tractor had a temporary problem when a piece of debris got into the glow plug hole.
   / HST 2615 Glow Plug light stays on #5
Witch one replaced the S85NE
2016 Ford Explorer...
PREVIEW DATES AND TIMES (A51572)
PREVIEW DATES AND...
2020 FOR TRANSIT CONECT CARGO VAN (A52577)
2020 FOR TRANSIT...
2020 Massey Ferguson 1840 Small Square Baler - High-Performance Hay Baler (A52748)
2020 Massey...
2018 Volkswagen Jetta Sedan (A50324)
2018 Volkswagen...
