HPX Tail Lights
/ HPX Tail Lights #1
Y2KF250PSD
Central Oklahoma
I've always thought the HPX should have taillights. Most of the other UTV's have them and I know Deere offers them as an additonal option. But, I decided to install the lights myself.
I picked up 2 small LED lights at a local AutoZone and installed them below the tailgate. The LED's are durable and can withstand the vibration and hard work this machine will see.
I wired them in with the headlights so they come on when you hit the switch. These little guys consume very little electrical power and are really bright!
Here's a pic of them in daylight, turned off.
/ HPX Tail Lights
A pic with them turned on, in a shadowed area.....
/ HPX Tail Lights
I'll throw this in too.
The little diesel is really stout!! Pulled my boat around with ease!!
/ HPX Tail Lights #5
Funny you should post this thread. I have been mulling around the idea of putting tail lights on my 6X4 Gator recently. In the last 2 weeks I have added a horn and a 12 volt outlet. The horn is great for getting the dogs and kids out of the way. The wife wondered what I would use the outlet for and the other day I had a 16ft utility trailer with low tires. I drove the Gator out there and plug in my little 12v air compressor and filled the up. How much did the LED lights cost?
/ HPX Tail Lights #6
In all the years I owned 6X4 Gators, I never thought about tail lights or a horn. After I bought an RTV that have both standard, I think they are a really good idea. Does the HPX still retain the Yanmar diesel? I pulled a 1200 pound cultipacker with a diesel 6X4 Gator for hundreds of hours putting in lawns. If you know what a culti packer is, you also know that it does not pull at all like a 1200 pound trailer. The Gator had such low ground pressure and was perfect for the job. I was amazed how steep of a hill that the little Yanmar would pull that heavy cultipacker up. Also, I never (really, never) had to replace the drive belt! It actually seemed less "jerky" starting off slowly after it wore some.
/ HPX Tail Lights
Brent,
They were right at 10 bucks each so I only have $20 in the outfit. They are made by Blazer and are labeled as "running board lights"
Plan on installing a ground strap from the bed to the frame otherwise the ground is intermittent. On my HPX, there was a pink wire looped out of the wire bundle under the hood that I tapped into. They evidently leave it looped out for adding the tail lights later so it made it easy.
I like the horn idea, it's next on the list. It'll be good for callin the cows!!
/ HPX Tail Lights
Dargo,
The HPX still has a Yanmar diesel bit it's a different engine (20hp) than the 6x4 (18hp).
I can certainly say, it's much stronger than the Kawasaki gas engine in my previous HPX. Both are 20hp and the specs indicate that the diesel only has one foot pound more of torque, but the torque is down low where it's needed.
It felt kinda doggy initially. I removed the spark arrestor (which is very restrictive) and it really pepped it up. Plus it's beginning to break in now and runs really smooth and quiet.
I can't stay off the **** thing!
/ HPX Tail Lights #9
On the horn, I got a horn from a Yanmar tractor, a push button switch from Wal Mart and then spliced it in to the hot wire on the back side of the ignition switch. There were already some holes in the frame work under the hood, so the horn bolted right on.
/ HPX Tail Lights #12
I like your lights, bet they're neater looking than the optional ones. Lights being optional struck me as odd or is this the coming trend, three point on some tractors optional, pto optional, sure hope it don't catch on.
/ HPX Tail Lights
Yeah, tell me about it!
The HPX only has headlights, and they shine on the ground directly in front of the machine. No way to adjust them so I used shims to raise them up. Now they shine out in front where they should.
Thanks for the comments guys!
/ HPX Tail Lights #14
I have been looking at adding tail lights to my HPX. Is the pink wire mentioned in this thread under the hood or the bed? I printed the wiring harness and rear light kits from the JD parts pages. The wiring harness show a group of connectors under the bed used for options. One is listed as rear lights. I turned on the headlights and checked with a meter put could not locate a wire that went hot with the lights on. JD has two kits. One provides tail and brake lights. The deluxe kit adds hazard and turn. Base kit is $120 and the deluxe kit is $295.
The JD kits have a rocker switch in the kit. Wonder if that turns on the tail lights separate from the headlight switch? It is not the brake, turn, or hazard switch as they are listed as well. Wonder if anyone has installed the JD kit or has the kit on there HPX and might know about this rocker switch?
Craig
/ HPX Tail Lights
The pink wire I tepped into is under the hood. You need to remove the storage tray and it was looped out of the harness right there in the middle.
Let me know if you can't find it, I'll take a pic and get it to ya.
/ HPX Tail Lights #16
I had the stock tail lights installed on my HPX and they are wired into the same rocker switch you use for the headlights. /forums/images/graemlins/smile.gif
/ HPX Tail Lights #17
I was wondering if the stock light kit plugs into a connector I see under the bed or the kit wire goes the entire way up to the front and into that pink wire discussed or right to the light switch. Under my bed near the pass frame rail there are three connectors for options. On the parts page one of those is labeled rear lights.
Craig
/ HPX Tail Lights
Craig,
I checked all the pins on the connectors under the bed but none of them were wired into the headlight switch.
But the pink wire under the storage tray up front is wired into the switch.
So, when I turn on the headlights, the tail lights also come on.
I thought for sure one of the plugs under the bed would have a feed from the H/L switch but apparently not.
/ HPX Tail Lights #19
Chuck
Thanks for confirming those connections under the bed. Was hoping I could have tapped in back there.
My dad visits more often now but I think it has something to do with the HPX because it's never in the garage long enough to tinker with it.
Craig
2023 KOMATSU D61PXI-24 CRAWLER DOZER (A65056)
2023 KOMATSU...
2023 JCB 3TS8T Teleskid High Flow Compact Track Loader Skid Steer (A66734)
2023 JCB 3TS8T...
BRIGGS & STRATTON STORM RESPONDER GENERATOR (A64276)
BRIGGS & STRATTON...
CAT R550/D11R Ripper Teeth (8) (A68134)
CAT R550/D11R...
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A66736)
2016 Ford F-150...
2018 MACK CXU (PINNACLE) (A67714)
2018 MACK CXU...
