HPX 4X4 locking 4wd on it's own....
   / HPX 4X4 locking 4wd on it's own.... #11
mine is supose to be engaged at just above idle speed . infact it come out of 4x4 easier if you bump the gas pedal a bit while disengaging it.
   / HPX 4X4 locking 4wd on it's own.... #12
I don't have clue what this unit looks like, but if it is a problem with it becoming magnetized, most metal working shops that do any grinding will have a demag unit that will take that magnetism out.
   / HPX 4X4 locking 4wd on it's own.... #13
i know when we used to have to weld on magnetized pipe the way we would demagnetize it would be to wrape the welding lead around it a few times while the machine was on and that would usually take care of it. did you check to see if the switch is closing all the way? try it with the wires fully disconnected or the battery disconnected and see what you get or did you try that?
You can leave it unplugged and it does the same thing.
   / HPX 4X4 locking 4wd on it's own.... #15
try takin the plate out and if you have a welding machine wrape the lead around it atleast 5 or six times and leave the machine on for a while infact if you can try welding on something else while you have the lead wraped around the plate the more amps the better. just cover the plate up so you don't get any b'b's on it plus you can spray it down with pam cooking spray to keep the b'b's off.
   / HPX 4X4 locking 4wd on it's own.... #16
You may also try one of the old handheld bulk tape erasers from Radio Shack to demagnetize.
David
Kb7uns
2000 Volvo VNL Sleeper Cab Truck, VIN # 4V4N21JF6YN250211 (A57453)
2000 Volvo VNL...
Mini John Deere Truck (A55853)
Mini John Deere...
EZ-GO Utility Cart (A55853)
EZ-GO Utility Cart...
(INOP) CATERPILLAR 914G WHEEL LOADER (A52705)
(INOP) CATERPILLAR...
Sterling AT (A55315)
Atlas Copco XAS90JD Portable Air Compressor (A57453)
Atlas Copco...
