HPX 4X4 Gator Electrical Problem
   / HPX 4X4 Gator Electrical Problem #1
simonds
Bronze Member
Steuben Co. N.Y.
John Deere 4200
My battery goes dead in about 2 weeks after charging. I checked the system with a tester and while runing it is reading 14.5 volts at the battery. So I'm assuming it is charging ok. I have checked for bare wires under the box and all looks fine. The key is off, so what could be draining my battery? Thak to any replies. Clayton.
   / HPX 4X4 Gator Electrical Problem #2
Review this You Tube Video and see if it will help you locate the problem. I would advise replacing the fuse if you pull it and see no change on you meter. Nothing like having a pile of 5-10-15-20 amp fuses and not know where they go.
How to check for Current Draw on a Vehicle - YouTube
   / HPX 4X4 Gator Electrical Problem #3
2015 PCI MFG. SOLUTIONS 130 BBL STEEL VACUUM TRAILER (A53843)
2015 PCI MFG...
2007 Honda CR-V SUV (A53424)
2007 Honda CR-V...
JUROP BLOWER (A53843)
2024 CATERPILLAR 299D3 SKID STEER (A52706)
2024 CATERPILLAR...
2021 FREIGHTLINER M2106 DEBRIS BUCKET TRUCK (A51406)
2021 FREIGHTLINER...
RIGID 1224 HAMMER CHUCK MACHINE (A53843)
RIGID 1224 HAMMER...
