Mowing HP to run 4" rotary mower
   / HP to run 4" rotary mower #1
F2036
How many hp tractor do any of you reccomend to run a 4' rotary mower?
I have a 26 hp gear drive and it will run a rear mount 66" finish mower but not to my satisfaction.
I'm wondering what it will take to run a 4' rotary(bush hog type) mower satisfactorally with a hydro trans. This will be in waterways and fence rows, some pretty tough mowing.
Any ideas or suggestions will be appreciated.
   / HP to run 4" rotary mower #2
I am running my 4' PTO rotary behind my Yanmar 1700D... I would bet it is close to 17HP so I can't imagine that you would have any difficulties. But maybe someone else knows more than I do so let them tell you differently.
   / HP to run 4" rotary mower #3
Minimum 5 HP per foot of brush hog. That will be stop and go in thick pasture grass. 6 HP per foot of brush hog will get you through most of the thick pasture and mow down some three inch trees. 7 HP per foot of brush hog will pretty much cruise through anything (diesel motors). Gas tractors won't pull as much as a diesel.
Thanks for the replys, this gives me some idea of what size tractor to rotary mower size is needed.
   / HP to run 4" rotary mower #5
What is the PTO HP?
My 30 horse tractor has 24 PTO HP (if I remember correctly - always dicey ) I have a 5 foot mower which works OK except in really tall grass - them I have to cut a couple of times.
   / HP to run 4" rotary mower #6
My 26HP/20HP PTO HST rig runs a 5' Bush Hog Razorback just fine. I've had to slow down in heavy stuff and take my time; but otherwise no complaints.
   / HP to run 4" rotary mower #7
My Massey Ferguson 1215 runs a 4 ft. bush hog quite nicely. I've gone through grass as tall as the tractor and over 1" dia. brush, but not both at the same time. It has nominal 15 hp PTO, but feels like it may be putting out a bit more than 15. The engine is rated at 18.5 hp.
   / HP to run 4" rotary mower #8
My Kioti CK 20 HST,18hp pto , runs my 4' KK hog just fine , have to slow down in heavy brush or grass. But thats a good idea anyway when you don't know whats in there.
In grass and light brush I go forward with bucket low to "feel" the way, good for finding hidden fence posts and rocks.
In heavy brush I go backwrds, it's slower but only need one trip over and I raise the hog and drop it slowly on the big brush and saplings. I can usually cutup just about anything I can push over with the back method, I have cut 3-4" easily. Only sheared one bolt in 4 yrs.
Another advantage of the backing method you aren't driving over and catching all that brush under the tractor and bending things ,pullling pins out etc, you get the idea.
   / HP to run 4" rotary mower #9
I ran a 4' hog on an old beater worn and abused Ford 1220 hydro... in 2'-3' grass it bogged down. but then that was a lawnmower sized tractor.. I'd say if you can get 18hp or so back there.. it's likely ok...
soundguy
   / HP to run 4" rotary mower #10
Being rather new to the bh scene, I recently bought a 5ft KK bush hog and it seems to run fine behind my JD 4120. It feels like the bh would fly apart before the tractor would lug. I dispatched some really large brush this past weekend without so much as a drop in rpms.
Gehl RT210 Turbo Skid Steer Loader (A50514)
Gehl RT210 Turbo...
New Wolverine Skidloader Sickle Bar Mower (A50774)
New Wolverine...
John Deere 648H  2 (A50322)
John Deere 648H 2...
2018 PETERBILT 579 TANDEM AXLE SLEEPER (A52141)
2018 PETERBILT 579...
UNUSED FUTURE MINI EXCAVATOR RIPPER (A51244)
UNUSED FUTURE MINI...
