HP requirement for each pump.
   / HP requirement for each pump. #1
J_J
Super Star Member
JACKSONVILLE, FL
Power-Trac 1445, KUBOTA B-9200HST
Do you guys happen to know the HP requirement for each pump? If not, just use the tech help on the Surplus Center's web site. For instance,
steering/lift pump puts out 3 GPM at 3000 psi, at 3600 rpm 6 HP
PTO pump puts out 12 GPM at 3000 psi, at 3600 rpm 25 HP
tram pump put out 7 GPM at 3000 psi, at 3900 rpm. 14 HP
Using a total HP of 45, and that is provided by a 45 HP Ford industrial gas engine, with radiator.
If you had to cheat a little on the replacement pump size, you probably could, because you are not using all function of the machine at the same time. You could also boost HP on the engine using various devices. How, would be up to you. For instance, I could add one of those Garret turbo charges on the output of the exhaust system. Then I would have one of the first turbocharged Power-Trac's. I can almost hear it now, screaming at full boost.
2012 Trail-Eze TE801 48ft 50 Ton Slide-Axle T/A Tilt Trailer (A51691)
2012 Trail-Eze...
(INOP) FORD 8N / 9N TRACTOR (A51247)
(INOP) FORD 8N /...
CASE TV450B SKID STEER (A51246)
CASE TV450B SKID...
UNUSED RAYTREE RMSC78-78" SOIL CONDITIONER (A51248)
UNUSED RAYTREE...
(2) UNUSED 3500# BRAKE AXLES (A51247)
(2) UNUSED 3500#...
BUYER'S PREMIUM INFO LOT NUMBER 2 (A53084)
BUYER'S PREMIUM...
