HP ratings of small engines
   / HP ratings of small engines #1
Gary Fowler
Super Star Member
Bismarck Arkansas
2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
It seems now days a garden tractor or lawn mower needs 25+ HP to pull a 42" deck. I can remember in the 70's that riding lawnmowers rarely had more than 12-14 Hp and pulled at least 38" mower really well. Have the engine manufacturers went to a different rating system for their power ratings. I have a 1987 model JD 332 diesel with 16 HP rating that pulls a 54" deck without a problem but I need 26 Hp on my ZTR (gas) to pull 52" deck under same conditions. Whats up with these engines now.
   / HP ratings of small engines #2
Gary,
I see it as a multitude of issues, marketing knows that listing a higher hp engine is a plus to most buyers and cost the manufacturer very little eztra money. Another thing is the speed at which the machine is moving, faster machine needs more power to operate. Lots of issues the last few years with the hp ratings themselves, most have switched to posting the torque specs instead after lawsuits. Hydrostatic systems have higher losses than the early gear drives so a little extra power needed to compensate for this.
I think most of the riding mowers and garden tractors have more power than you really need, I know my L130 gas and X749 diesel mowers don't bog down enough to hear it.
   / HP ratings of small engines #3
People are so much fatter these days over the '60 and '70 the lawn mowers need that extra ten horses just to lug the rider around the yard. The mower still uses the same power for the same width deck but put a year 2011 guy in the seat and a bit of a grade to the yard and it becomes obvious why they had up the horsepower in todays mowers.
   / HP ratings of small engines #4
I had a 1971 Cub Cadet Garden Tractor. It was 10hp.
It ran a 48 in deck and a 36 in rototiller. it would run a 42 single stage snowthrower...As far as needing more hp to haul hefty riders, a new 25hp lawnmower weighs 300 lbs... My 10hp Cub Cadet weighed about 750 lbs... It actually had the same trans and rearend as a farmall cub.
The new "Lawnmowers" seem to be built as a throw away... If I had an acre or less of lawn to mow, I'd buy a commercial walk behind...
Regards,
Chris
   / HP ratings of small engines #5
There was a lawsuit about the HP ratings being 99.3% fiction and 0.7% marketing a few years ago. Now most push mowers are rated by the displacement. Seems the mfg's were all allowed to "estimate" HP. When sales were down, the HP grew the next year. Since the displacement, carb, and compression were identical -- I wonder how they did that?
   / HP ratings of small engines #6
The lawn mower class action suit covered nearly every brand and many thousands of customers got checks from the companies. They lied about the HP and got caught that time. I'm sure the payout was a fairly small portion of the profits made, so probably no one got hurt very bad. They most likely got a bit more back out of creative tax write-offs.
   / HP ratings of small engines #7
The love affair with MULCHING! has a lot to do with needing more HP. Belts also lose you about 15% of the HP right off. Not sure how much a pure gear based PTO loses, though.
I swear. The number of people blowing belts this year because they were mulching 8" wet grass was astounding.
   / HP ratings of small engines #8
I got three checks for over rated HP on garden tractors<JD> and one for a Cub cadet. The engineering spec in not to reflect a Peak HP but an American engineering standard. Horsepower sucks gas and the more HP the more gas. They did me a favor when the gave me 23HP Mowers and claimed they were 25HP. With a 100 million mowers in the USA that saves a lot of gas. Truth is we could get by with a lot less HP and torque. Remember the old 8N/9N and others only had about 24HP and good torque for a two bottom plow. People made a farm living with them. Shure beat the **** out of the mule my brother in law plowed with.
I seem to see the same in cars and trucks. I had a stock 351 Clevand engine in a 1970 Ford Torino that supposedly had only 275 HP but would smoke the biggest tire made at the time and hide the needle (120 MPH) in less than a half mile, over 85 MPH in a quarter mile and now we have 4 cylinders with claims to that much hp and more that wont do half (well maybe half) as much in performance. I could also get 19 mpg running over 75 miles per hour with that Torino but that was with real gas at over 100 octane. The book said not to use anything less than 101 octane. I sold it in 1974 because I could no longer get gas at the pump that wouldnt knock. I just dont believe most of the HP ratings that come out with any motorized vehicle now.
   / HP ratings of small engines #10
Tires are exponentially grippier now than they were in the 70's. Not only that, but your 275 1970 horse power was more like 125 by today's measurement. A new Rav4, a grocery getter by any sense of the word, can do 0-60 in 5.7. That's faster than a 1990 Ferrari.
Being able to just melt tires in a RWD with 125 HP and having a FWD econobox with nearly 300 HP being unable to do so really shows how far the technology has come.
3 - RIDGID THREADERS (A53843)
3 - RIDGID...
2011 TEM 50' FLARE STACK (A53843)
2011 TEM 50' FLARE...
2021 FORD F-150XL CREW CAB TRUCK (A51406)
2021 FORD F-150XL...
2017 TROXEL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXEL 150...
2010 PETERBILT 367 HOT OIL UNIT (A53843)
2010 PETERBILT 367...
