HP Rating: Gross or PTO???
   / HP Rating: Gross or PTO??? #1
Neophyte
Platinum Member
ME
John Deere 3320 eHydro with 300CX FEL
When looking at attachments, they often have recommended HP ratings. However, they don't specify if gross or PTO HP. Are these Gross HP ratings for the tractor overall or PTO HP ratings?
   / HP Rating: Gross or PTO??? #2
I'm not sure, but I always use my PTO HP as the number I want to compare attachment HP numbers to when deciding if I am within the limits.
   / HP Rating: Gross or PTO??? #3
If an implement requires the power if a PTO, IE a tiller, then the PTO HP is what is needed to safely operate that implement.
   / HP Rating: Gross or PTO??? #4
CCI is right. Gross hp really doesn't mean alot. It's how much power you put to the pto that matters. Doesn't do you any good to have say a 60 hp tractor and only have 40 hp at the pto if you need 50 hp at the pto. Depending on the engine and tractor make the gross hp is anywhere from 20-40% greater than the pto hp.
OK, that makes sense.
Non-PTO implements (box blade, rake, etc.): Use Gross HP
PTO Implements (rotary cutter, tiller, etc.): Use PTO HP
Is this correct?
   / HP Rating: Gross or PTO??? #6
I would use Net HP for Non PTO implements instead of gross. Gross HP is the HP the engine produces without any water pumps, Alternator,etc. Net HP is the HP that the engine really puts out to the tranny.
For 20-40HP tractors, is it safe to assume that Net HP is usually only 1-2HP less than Gross HP?
   / HP Rating: Gross or PTO??? #8
</font><font color="blue" class="small">( For 20-40HP tractors, is it safe to assume that Net HP is usually only 1-2HP less than Gross HP? )</font>
I wouldn't assume that.
It seems to me that, generally speaking, you can expect about that much of a difference for a gear tranny tractor. Then knock off a couple more hp for a shuttle shift transmission, and even a few more for a hydrostatic transmission. I think I've seen as much as a 10 hp difference in gross vs. pto for a hydrostatic transmission.
I'm sure others will have even more accurate inforrmation. But it's easy enough to check out the specs when you're shopping around. /forums/images/graemlins/wink.gif
   / HP Rating: Gross or PTO??? #9
<font color="blue"> For 20-40HP tractors, is it safe to assume that Net HP is usually only 1-2HP less than Gross HP? </font>
Garry gave you some great insight above. The example to which I'll refer is my own JD 4200. I believe the gross HP rating is something in the 26-28HP range. My PTO is rated at 20HP. That translates into a gross HP rating 30-40% higher than the PTO HP rating. Quite a difference, to say the least. /forums/images/graemlins/smile.gif
   / HP Rating: Gross or PTO??? #10
As Garry and Gary (and now this Gary) have said, the PTO hp drop from a gear tranny is a bit less than with hydro. PS also takes up hp. My tractor (gear) is 20-21 hp at the engine and 17 at the PTO. Not as much drop. If you use the PTO listing for your tractor, you should be ok when buying implements that need XX hp. Now, do the Garys have you confused?
(9) ROLLS OF 5' - 10 GAUGE CONCRETE WIRE (A54757)
(9) ROLLS OF 5' -...
2017 Bobcat T770 Compact Track Loader (A56435)
2017 Bobcat T770...
33ft Dovetail Flatbed Trailer (A56435)
33ft Dovetail...
Adams Load Out Conveyor - Stainless Steel Assembly - Baldor Electric Motor (A56436)
Adams Load Out...
2006 Mercedes-Benz (A55758)
2006 Mercedes-Benz...
2015 GENIE S-45 TELESCOPIC BOOM LIFT (A52709)
2015 GENIE S-45...
