HP how much do I need?
/ HP how much do I need? #1
F2036
How much HP do I need to run a 60" tiller and a 60" rotary mower?
Would a 3215 be enough tractor?
I would like to stay 60" or less in width of tractor if possible.
Thanks for any ideas or suggestions.
/ HP how much do I need? #2
I would expect it would. I have a Kubota L3700, which is not much more HP and Kubota specifies a 60" tiller for it. I pull a 60" rotary cutter and have plenty of power even in high grass and heavy brush.
/ HP how much do I need? #3
+1 Use both just fine on Kub L3450& L2550.
larry
/ HP how much do I need? #4
If you go HST, you'll be fine. I'm running a 6' tiller and brush hog on an L3710. I have a neighbor doing the same with a slightly bigger geared tractor and he spends a lot of time shifting.
/ HP how much do I need? #5
My 3215 has plenty of power to run my 60" Bushhog mower. My track width is 61" with R4s.
/ HP how much do I need? #6
I use a 58" tiller with my 3215HST with no problems. Most likely could use of a 72" tiller with out any problems. So yes you would be fine with a 60" tiller behind a 3215.
2021 Ford Transit 350 HD Reefer Box Van (A64194)
2021 Ford Transit...
Interstate 20ft Tilt-Deck T/A Flatbed Equipment Trailer (A64553)
Interstate 20ft...
Dixie Chopper (A64557)
2017 BOBCAT MT85 STAND-ON SKID STEER (A65053)
2017 BOBCAT MT85...
2006 FORD F-150 XL TRITON EXT CAB TRUCK (A64276)
2006 FORD F-150 XL...
2009 Ford F-450 Ambulance (A64556)
2009 Ford F-450...
