HP for landscape rake?
/ HP for landscape rake? #1
QuasarZ
Western WI
Previous Branson 2400H. Looking for new
I am looking into buy a landscape rake. How much horsepower is required to pull a 5 or 6 foot rake? I have a Branson 2400H (24hp) and don't want to go too big. Will be using it to rake up depris (leaves, twigs, branches, some logs, rocks etc) and also smooth out my land after we build to prep for seed.
Thanks!
/ HP for landscape rake? #2
I have a 5' rake for my 21 hp B7500. Never had any problem pulling it. I expect that traction will be a bigger issue than horsepower.
/ HP for landscape rake? #3
They are not real bad horsepower hogs, but like most things it depending on several factors (hills, how/what you are grabbing, etc). I can pull a 5' on 23 hp without any real problems doing gravel, light brush and such. My big thing was I wanted to cover the tire tracks when I am working but not have it so big I can't fit easily between the trees.
/ HP for landscape rake? #4
I have a Woods LR72 6 foot on my 2400H. If you want to use it like a box blade and drag a full load of dirt your will spin out before running out of power. Other wise with the gauge wheels it works great for leveling my drive way.
/ HP for landscape rake? #5
I pull a 5' Woods LR with a 17 HP B1700...no problem at all...
I actually made some end plates and made it a "box rake" works amazingly well and does not leave any windrows of gravel debris etc...
If you do not have hydraulic top and tilt the gauge wheels will help...
/ HP for landscape rake? #6
VERY good point. top and tilt will make rake work much easier and faster but if you don't have T-n-T the gauge wheels will really help you and are worth the extra money.
/ HP for landscape rake? #7
I'm also looking for a landscape rake. Are you saying if you have top and tilt you don't need the gauge wheels? Or should I buy the gauge wheels anyway? I do have the top and tilt.
/ HP for landscape rake? #8
Kubota B2710 (23 hp IIRC) here for the landscape rake (6' Landpride). Never an issue with power although it could use some front end weight when I left the rake off the ground.
However, I do not suggest a landscape rake for twigs, branches, etc. They tend to get caught between the tines and are difficult to get out.
Mine has the gage wheels and I wouldn't consider one without the wheels!
Thanks for all the replies. There is a used Frontier 72" with wheels on craigslist for 500 or I can get a new TSC brand for 499 without wheels but I saw the TSC is made by tarter and they have a wheel kit but not sure how much.
/ HP for landscape rake? #10
For $500 with the wheels that's a decent deal if the tines are not bent out of shape - a wheel kit is $200 range I think - as others have said a wheel kit is great to have.
What about a Befco for 250 without wheels? Says about a month old.
/ HP for landscape rake? #12
With Hyd. T&T I have found no need for the wheels...you can keep the rake perfectly parallel with the surface but it may require frequent adjusting of the T&T...but the results are darn near perfect...You may find that using the wheels requires height adjusting also and this requires climbing on and off the machine...i.e. change the aggressiveness attitude of the rake and the wheels will need adjusting too...etc.
Good luck guys...you will love your rakes...very easy to learn to use effectively and efficiently...
/ HP for landscape rake? #13
As /pine said, with Top and Tilt I don't find the wheel necessary. $250 without wheels in good shape does not sound bad at all!
/ HP for landscape rake? #14
Are you saying if you have top and tilt you don't need the gauge wheels? I do have the top and tilt.
One gauge wheel juts out pretty far when the rake is pulled angled. Therefore, rake is more maneuverable without gauge wheels.
Note: I do not have T'nT. I use gauge wheels most of the time with my ETA Landscape Rake. Gauge wheels require regular height adjustment during jobs for optimum effectiveness.
A pair of ETA gauge wheels are $299-$349.
/ HP for landscape rake? #16
/ HP for landscape rake? #17
A 5' would be the best size for your tractor. A 6' could be cut down to 5' or you could just unbolt some tines to make it 5.'
2012 INTERNATIONAL PROSTAR+ 122 6X4 ROAD TRACTOR (A65054)
2012 INTERNATIONAL...
PALLET OF HOSE FITTINGS AND HEAVYEQUIPMENT PARTS (A68842)
PALLET OF HOSE...
2014 ALLMAND MAXI-HEAT PORTABLE HEATER / GENERATOR UNIT (A67714)
2014 ALLMAND...
GENERAC MOBILE PRODUCTS MLT6S LIGHT PLANT (A68842)
GENERAC MOBILE...
2018 GENERAC MOBILE PRODUCTS MLT6S (A67714)
2018 GENERAC...
Front Tank Bracket (A64126)
Front Tank Bracket...
