HP and a/c
   / HP and a/c #1
jimg
I know Ive seen this somewhere in TBN but I cant find it. So Ill ask again but only in regard to NH tractors....how much hp should I expect a/c to consume in a new tractor? Does it depend on model? How about older models (mid 80s to 90s models)? I would expect theyd be less efficient but by how much (assuming the a/c unit is in good working order)? Just so I understand this correctly...if Im consuming x hp for the a/c thats x hp less Ill have at the PTO? In other words PTO hp figures dont include other power drains (like a/c).
   / HP and a/c #2
It was about a years ago, in the JD forum.
   / HP and a/c
Im not finding it...Ive looked in both forums for all of the likely variations/combinations of air conditioning and horsepower (including abbreviations). Do you recall if the title is about this topic in particular or did it morph into that as the discussion progessed?
   / HP and a/c #4
Richard (cowboydoc) was the main one discussing it from his own experiences. Toss him a PM and fire the questions at him or go to the general board and ask
   / HP and a/c #5
With the newer TN series of tractors, it isn't an issue. I have a 2 year old TN65D with cab and it seems the a/c unit uses so little power, it isn't an issue. I've pulled a 3 bottom plow while using the a/c cycling it from off to on and no noticible decrease in power, ground speed or rpm. I've pulled a 13 foot disc and a 6 foot mower with the same results- NOTHING! It makes no difference to the newer tractors. Ken
   / HP and a/c #6
   / HP and a/c #7
I agree with Ken. On my TN75D, switching the a/c on and off has no noticable effect on power. I suspect that the a/c is using a hp or 2, but that these engines have such significient torque reserve that they just producte the small amout of extra power required and you don't notice it.
Andy
   / HP and a/c #8
Andy
   / HP and a/c
I could believe that new tractors would be very efficient. However, a new tractor isn't in my future as the cost is just too high. If I can find a good used TL or TS that would be nice but I think Ill wind up w/ something a bit older. My impression is that older machines won't be so efficent.
   / HP and a/c
2012 Caterpillar AT1055E Track Asphalt Paver (A51691)
2012 Caterpillar...
MI-T-M PRESSURE WASHER (A52472)
MI-T-M PRESSURE...
Ryobi Compound Miter Saw (A51573)
Ryobi Compound...
SKID STEER HYDRAULIC TREE PULLER (A52472)
SKID STEER...
WB Mower (A50120)
WB Mower (A50120)
2025 New/Unused Wolverine Pallet Fork Extensions (A51573)
2025 New/Unused...
