Hoye overrunning clutch for ym1500
   / Hoye overrunning clutch for ym1500 #1
ziggywiggy
Yanmar 1500
Does anyone use the quick detach clutch, is it supposed to be flush to the back of the pto? Greased up pto and clutch really well, but there's still an inch of space. I just want to make sure that it's attached correctly.
   / Hoye overrunning clutch for ym1500 #2
You can tell when it is in the right spot because the spring loaded pin in the clutch will snap back in place. The pin has to slide into the groove in the PTO shaft. Also be sure you trim your PTO shaft if needed to accommodate for the extra length of the clutch and use only 1st PTO gear.
Thanks for the reply, the pin did snap back so it sounds like everything is good to go. I was worried if it wasn't on there correctly it would become a projectile so I wanted to be sure.
2012 Ford Edge SUV (A50324)
2012 Ford Edge SUV...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52748)
80in HD Tooth...
Landoll Hauloll (A52748)
Landoll Hauloll...
2017 GENIE GS-2646 (A52472)
2017 GENIE GS-2646...
2020 Polaris Ranger 1000 4x4 Utility Cart (A51694)
2020 Polaris...
2025 78in Dual Cylinder Hydraulic Grapple Rake Skid Steer Attachment (A50322)
2025 78in Dual...
