Disc Harrow HOWSE LTR SERIES DISC MANUAL
   / HOWSE LTR SERIES DISC MANUAL #1
KHM65
Edna, tx
New Holland TC29
I recently bought a Howse LTR20822B disc. It is in good shape, I need to do a little work on it and re-set the blades to less aggressive. But I do not have an owners/user manual. Does anyone have a manual they can share with me?
Thanks a lot,
Ken
   / HOWSE LTR SERIES DISC MANUAL #2
Thanks a lot,
Ken
Ken,
I have recently bought the same disc, did you find the adjustment instructions? I have a [AFFILIATE=1, nofollow=true, newwindow=true, title="Kubota"]Kubota[/AFFILIATE] L3200 to pull it with and think this disc is on the upper end if my tractor will pull it, comments please.
Thanks,
Tom
   / HOWSE LTR SERIES DISC MANUAL #3
   / HOWSE LTR SERIES DISC MANUAL #4
Howse Model DLHT 20822B
This 6 ft disc harrow has a powder coat painted heavy duty 2" X 3" tubular frame with 3" X 3" tubular arms. It comes standard with adjustable gangs, ball bearings, 1" axles, 7 1/2" spacing, double u-bolts, clevis style hitch, 18" blades, and is quick hitch compatible.
Discs with 7-1/2" pan spacing are designed for smoothing plow furrows.
If you have no interest in breaking new ground, and if your L3200 has 4-WD, the [AFFILIATE=1, nofollow=true, newwindow=true, title="Kubota"]Kubota[/AFFILIATE] L3200 should pull the Howse "OK". Certainly this disc is at the upper end of what your L3200 can pull on a second pass when the ground is soft.
Tractor weight is the key factor.
Less important factors are rear tire fill (air or liquid) and tire type (R1/ag tires provide better traction on dirt than R4/industrial tires).
   / HOWSE LTR SERIES DISC MANUAL #5
I have a Kubota L3200.
Kubota L3200
Kubota L3200 tractor photo
2011 - 2014
Standard L Series
Compact Utility tractor
Kubota L3200 Weight
2,425 lbs (2WD gear)
1099 kg
2,601 lbs (4WD gear)
1179 kg
2,623 lbs (4WD hydro)
1189 kg
KUBOTA M7060 TRACTOR (A51243)
KUBOTA M7060...
Kubota L503OD 50HP Utility Loader Tractor (A50322)
Kubota L503OD 50HP...
KUBOTA L2650 TRACTOR (A51243)
KUBOTA L2650...
Unused Delta Crash...
John Deere TX 4x2 Utility Gator (A49346)
John Deere TX 4x2...
1997 INTERNATIONAL 8100 4X2 WATER TRUCK (A50458)
1997 INTERNATIONAL...
